Old 05-09-2024, 10:35 PM   #1
HONK
*Honker*
HONK's Avatar
Default Will a pressure washer thing work on a tap with a weak flow?
I am considering buying some kind of car washing backpack jet stream thing from the internet, it plugs into the tap or what not and is a pressure washing thingo.
My tap outside has a weak flow, as if the tap was only turned a quarter of the way.
Would that work with a pressure washer? I hear it uses less water than a normal hose, so...
HONK is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2024, 10:38 PM   #2
Default Re: Will a pressure washer thing work on a tap with a weak flow?
Is it on Temu?
Old 06-09-2024, 01:23 AM   #3
Crazy Dazz
I don't know about backpacks, mine have always just had wheels.
Also not sure about using "less water"? The beam is concentrated, but it's very high pressure. Certainly I have discovered that if the flow is obstructed, eg the hose gets caught, the washer will "starve" and splutter.
These washers normally specify a pressure, and obviously the more expensive models can generate more pressure. So a smaller, lower pressure, unit, would require less water.
Making Whine from the Tears of Hippies
Old 06-09-2024, 06:29 AM   #4
I'm on tank water and my pump is nowhere near the level of town water for pressure. My pressure washer works fine.
Old 06-09-2024, 07:04 AM   #5
If water flow in is equal to or greater than waterflow out, you'll be fine.
Old 06-09-2024, 06:17 PM   #6
Ha ha, I highly doubt my pressure washer is saving me any water at 10.5-liters per minute using a 4.5 orifice.
From a normal town water supply by the way. I did need a 15-amp plug though.
DFB FGXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2024, 07:17 PM   #7
CyberWasp
CyberWasp's Avatar
Some brands do.
Running one from a bucket would be the lowest pressure possible.
You still need a little gravity to get it to work hence putting the bucket higher than the pressure washer.
2004 Mercury Silver Falcon XR6T - 5 Speed
2017 Platinum White Mustang GT - 6 Speed
2022 Blue Thai-Special for Daily Duties - Auto
CyberWasp is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2024, 07:18 PM   #8
swamp
hi
Normal house mains pressure is 35-45 psi. Commercial upwards 65psi
Water flow is around 40ltr per minute for domestic house
flow is measured by how many litres in a 15 second duration . Then x 4 =Litres per minute.
For a pressure cleaner keep the supply hose [typical 1/2 inch ] short as possible
Most important use an inline water disc filter in the supply hose . The grit and occasional small pebble will damage the pressure cleaner . Warranty is also void if debris /damage is found internally .
swamp is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2024, 09:31 PM   #9
MITCHAY
I have a cheap Karcher K2 from Bunnings years ago and always on tap water and just spent a couple of hours cleaning up mums pavers with shit flying everywhere
MITCHAY is online now   Reply With Quote Multi-Quote with this Post
Old 07-09-2024, 08:44 AM   #10
roKWiz
Cabover nut
roKWiz's Avatar
Smaller country towns around here tend to have a lower town water pressure supply.
(if they are on town water at all)
Certainly more than the average person needs but
I bought a used (Aussie pumps) petrol powered unit simply because it could boost the pressure up to 3800psi but is quite suitable for the purpose of washing the top and underside of my trucks along with long stored granite.
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2024, 08:40 AM   #11
All over the fence, and the neighbour’s windows/walls?
Thread reminds me of a mate troubleshooting his home installed EFI conversion fuel system. “I’ve got pressure, but no flow”. I suggested this was the Bachelor’s Lament.
Old 08-09-2024, 10:40 AM   #12
HONK
*Honker*
HONK's Avatar
This is what I needed to hear.
Old 08-09-2024, 10:41 AM   #13
HONK
*Honker*
HONK's Avatar
I will give it a go.
Thanks for that.
Old 08-09-2024, 11:46 AM   #14
Further to what CB alluded to in his earlier post, make sure you buy a pressure washer like one of these types:
If you buy one like these below, you will be disappointed:
I’ve seen ads recently that claim all sorts of great things about these hose nozzles that cost about $49, and one of them was called a “jet washer” or something like that.
Old 08-09-2024, 12:00 PM   #15
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Same deal here, but in peak demand times 6AM-9AM water pressure drops significantly because of infrastructure issues, to the point it effects having a shower.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 08-09-2024, 12:09 PM   #16
Interceptor
HSV - I just ate one!
Interceptor's Avatar
the average, hand portable size pressure washer should be fine with whatever you're getting from your tap.
once you get into bigger, commercial/pro grade stuff, then you need to worry about flow.
showoff!
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2024, 05:02 PM   #17
showoff!
Show off? Well, knowing where this thread was going to end up, I couldn't resist!
In any case, my point being, if a commercial-grade machine can draw enough water from a normal town water supplied outlet, a crappy entry level machine won't have an issue. End of thread!
Old 10-09-2024, 08:30 PM   #18
351buzz
351buzz's Avatar
My old karcher hot water washer outflows my gravity feed tap.
Was fine when on tank water, tank was high up a hill, but now gravity fed by a lower dam,no good. Problem is it has its own reservoir (5L) with a float valve in it. It will empty out the reservoir before the gravity feed tap can refill it.
Just dawned on me while reading this, i might just bypass reservoir and plumb straight into tap so it can suck from supply. Piston type pump like in pressure washer should do that easy enough.
351buzz is offline   Reply With Quote Multi-Quote with this Post
