Old 11-06-2024, 04:50 PM   #1
JIm260
2004 XR8
JIm260's Avatar
Default Replaement Disc Rotors EF Fairmont Ghia 4.0
Hi Does anyone have any experience with RDA disc brake rotors and pads, are they any good compared to DBA products?
Jim
JIm260 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2024, 06:18 PM   #2
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Default Re: Replaement Disc Rotors EF Fairmont Ghia 4.0
I prefer DBA over RDA rotors, from my experience in the Taxis.
Never used either type of Pads.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2024, 09:11 PM   #3
ute83
Rotors are fine. Get yourself some good semi metallic pads like trw.
ute83 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2024, 01:25 PM   #4
123Cat
Do the semi metallics bite more
My ceramic pads are lazy , thanks
Fords are cool
123Cat is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2024, 09:14 PM   #5
ute83
I had rct ceramic formula pads on my jetta. They left pad material on the disc to the point of shudder. And the rotors never cleaned up. As an experiment I changed to a trw pad and the same rotors cleaned up nicely but couldn't reverse the dtv. Now has a set of rda rotors with the trw pads. No more shudder, rotors are flat and clean. The repco pads are in the bin. I will stay away from ceramic pads.
