Go Back   Australian Ford Forums > The Sales Yard > Cars for Sale
Cars for Sale Complete or nearly complete Cars for sale. Note: ALL transactions in these forums are done at your own risk. FordForums Australia Inc. does NOT take responsibility for any aspect of any item or transaction that may take place via the site.
Old 02-04-2024, 04:42 PM   #1
MercurySilver
Isn't it obvious?
MercurySilver's Avatar
Default (SA) Ford Falcon 1975
Vehicle Sales Form
State
: SA
Make of vehicle
: Ford
Model of vehicle
: Falcon
Year of manufacture
: 1975
Colour of vehicle
: Mushroom Beige
Engine
: 200
Transmission
: 3 speed column manual
Body style (sedan, wagon etc.)
:Sedan
Selling Price $
: 15000
Odometer Reading
: 106000
City
: Barossa
Other relevant information.
1975 XB sedan
200 Hi Comp
3 speed manual column shift all synchro
saddle trim
mushroom beige paint
original motor done 106000 on the speedo, the book has service history up to 68000
i am the third owner
Currently the car is semi dismantled
motor and box still in, loom still in, brakes and suspension all untouched, car rolls and turns by hand fine, motor has no battery, fuel tank still in, column lock still works.
Condition
rust above the rear tail lights, not major just the top section of the light surround
still have the tail lights and they are uncracked, one side has a small piece of tin(?) rivetted across
the rear screen on the edges down the middle has rust and would need to be repaired, the bottom screen corners aren't terrible but will need repairs as well
side sills have a little at each end but certainly not bad at all by any means
doors are on the car but not perfectly aligned
doors have had small bog repairs in the corners on the front sides but nothing is thru the whole door, surface rust only on the undersides of a couple of them, close up to see the worse one which isnt bad at all
inner sections under the guards have a little rust but nothing major
under the hood seems to be free from any bad rust
floors look good from above and below and sounds solid
rear parcel is great (can just see a little surface coming up in that 4th pic from underneath which will correspond to the rear screen corner)
Boot and fuel tank look clean
Guards prob look the worst
rear boot wells will need a small repair as well from what i can feel, but nothing bad by any means
front grille has the tabs busted like usual, threes also a crack in the centre of the nose, nothing a plastic welder couldn't fix, the chrome strip on the grille edge is still there and fine, both honeycomb pieces all in tact all the fins are fine, headlight areas fine, just the crack in the nose and the inside tabs are bad
crash pad is excellent, no tears or marks at all
doors skins good
also have a GT bonnet to go with the car, its dark green in colour and needs a repair on the end, have a pair of scoops and a set of pins
have all inner and outer door handle bits, all work
all latches, both sunvisors, the front seatbelts, the original headliner i have,
carpet was gone and had to be binned,
have front inner footwell covers,
all glass is wrapped, have both rear qtr windows, all winding mech,
all wipers, wiper bottle, battery tray
kept all the rubbers and the door felts, some could possibly be cleaned up and reused.
have the dash surround, the speedo and fuel gauge, the glovebox, all stored clean and in very good condition
have the original crash pad which is a 9 out of 10 no rips or scuffs
have the windscreen chrome surround with the rear still being in the rubber on the rear screen
have the black/chrome side strips that go across the door centres
have the plastic door sheets from behind the door trim
both bumpers very good no dings, little surface speckle in some parts
have a pair of front and rear over riders, rubbers good on all but one which has the lug snapped off from the back but can still be used
back seat rear top has gone but base is fine
front bench has splits on the drivers side, tops of both sides of front bench and base of passenger side front bench are good (from memory)
front indicators good
glove box good
boot very good still has the jack sticker on it
have a jack for it, have a spare that came with it
have all four fairmont hubcaps
have the headlights and brackets
please don't low ball me
i'm not in a rush
i'm not letting it go cheap
yes im open to decent offers around WHAT IM ASKING
i've had it for around 11 years
genuine buyers only please
please dont message whats the lowest etc, ill just ignore it
08 Strike G6E T.
10 Ergo G6E
Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens
MercurySilver is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2024, 05:28 PM   #2
MercurySilver
Isn't it obvious?
Default Re: (SA) Ford Falcon 1975
08 Strike G6E T.
10 Ergo G6E
Old 02-04-2024, 06:02 PM   #3
MercurySilver
Isn't it obvious?
cant edit posts after 30 mins so ill add another
(mods/admin please amalgamate as you see fit)
and thanks to those that helped with image upload info (very helpful)
heres a link to a gallery with some pics of whats in the description
https://postimg.cc/gallery/3HxYVYTc
any questions i can always chuck up more pics
cheers
merc
08 Strike G6E T.
10 Ergo G6E
Old 02-04-2024, 06:42 PM   #4
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
There you go, lots of pics!
Swanny’s Fundraiser for the 2024 MS Brissie to the Bay Bike Ride
2016 Ford Falcon FG/X XR6 Turbo you beaut ute
1985 XR4Ti Sierra - Build Thread
1971 Fairlane 500
and... a collection of Jeep Towpigs
and... two collections of rust and some new plastic bits roughly shaped like an F-Truck
and.... some spare metal bits with holes in them
Captain Stubing is online now   Reply With Quote Multi-Quote with this Post
Old 02-04-2024, 06:43 PM   #5
Captain Stubing
Part II
1971 Fairlane 500
