Old 07-02-2024, 02:39 PM   #1
Davebatts46
Default BF Ford steering wheel buttons not working.
The Mode, Seek and volume buttons on steering wheel are not working on my 2006 BF Ford Falcon. I have changed out the buttons no change. Then it was suggested that the clock spring was broken got a used one from the wreckers and installed it. Still not working. Appreciate any help in fixing this problem.
Davebatts46 is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2024, 08:11 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: BF Ford steering wheel buttons not working.
Hi. Has the car ever had an aftermarkt radio fitted to it? Quite often you will find that the red/white wire under the steering column gets cut so it can be used to work with a different stereo. Have a look in the white six pin plug at the base of the steering column shroud. If the wire is OK you can use it as a test point with a multimeter to see if the resistance to earth changes when you push the buttons. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
