Old 16-08-2022, 01:59 PM   #1
ben131185
Default Rear Demister
Rear demister isn't working.
No light on the dash and no clicking sound of a relay when button is pressed.
Recently had the auto elec's pull the dash out to replace blower motor, and change globes behind the odometer in the cluster (which have just stopped working again).
Is the demister light in the cluster part of the circuit? could they have swapped that globe into the odometer causing the demister to stop working? or have they just not reconnected a wire somewhere?
Any help would be much appreciated.
ben131185 is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2022, 02:19 PM   #2
ben131185
Default Re: Rear Demister
It turned out to be a couple of plugs around the wrong way.
there's an orange plug the same size behind the panel next to the deminster switch, swapped them over and back to normal.
