Old 31-03-2022, 10:05 AM   #1
Vesper Martini
Vesper Martini's Avatar
Default Painting Alloys
Thoughts and recommendations please
I have one set painted gloss Black, but they have started to flake so will need touching up.
and another set of perfect condition factory BMW 20" staggered alloys - Id like these black also get them painted or swap them for wheels already painted
and where is the best places Located in Victoria
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2022, 10:42 AM   #2
Cav
HUGH JARSE
Cav's Avatar
Default Re: Painting Alloys
Do it at your place unless the rims are damaged
Check out youtube
https://www.youtube.com/results?sear...g+alloy+wheels
BTW white is the new black
Cav is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2022, 10:49 AM   #3
Bossxr8
Peter Car
Bossxr8's Avatar
Powdercoating not an option?
Old 31-03-2022, 10:55 AM   #4
Vesper Martini
Could be - that would do a better job and last longer.
depends on the cost compare to getting new wheels, they Tyres would have to come for anyway for that
Old 31-03-2022, 11:00 AM   #5
Vesper Martini
Check out youtube
In years past that would be the way Id attack it, but I'm seeking a professional job. and frankly just don't have the time weekends are full as it is.
Old 31-03-2022, 11:23 AM   #6
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
I've used Tin God Solutions. They PC'd my KG wheels and over painted in a highlight. They are more of an old aircooled specialist but may be able to suggest someone else if they can't help themslevs
https://www.facebook.com/tingodsolutions/
simon varley is online now   Reply With Quote Multi-Quote with this Post
Old 31-03-2022, 11:41 AM   #7
T3rminator
T3rminator's Avatar
I drove past a place called Black Ace Powdercoating in Bayswater just before new years. I asked how much it was to powder coat the wheels I had the time, which were territory 18s. The wheels were still in excellent condition, so the guy said $50 each as he didn't need to do much to prep it.
There is not a lot of info on that business, but they had a lot of stuff being powder coated in the factory at the time, so I'm assuming they have some business. You could call them and ask about yours.
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is online now   Reply With Quote Multi-Quote with this Post
Old 31-03-2022, 11:50 AM   #8
Vesper Martini
Cheers sounds like a bargain, just called and he confirmed the price.
Ill need to remove the tyres wheel weights etc.
he said for the other ones that are flaking Id need to get them sandblasted first which makes sense
Old 31-03-2022, 01:23 PM   #9
T3rminator
T3rminator's Avatar
It did seem like a bargain and a half. I would have followed through if I didn't change my wheels. Keep us in the loop on the quality of the work. If its decent I may get some other stuff done there.
Old 31-03-2022, 04:32 PM   #10
Vesper Martini
I was thinking the same thing, Ill pop in and see them next week
Old 31-03-2022, 05:18 PM   #11
XRtowcar
Mustang GT mmmmmm......
XRtowcar's Avatar
Just had some wheels painted two pack silver.
Was going to get them powder coated but some forums are suggesting it can soften the properties of the aluminium and change the strength of the wheel.
Panel shop did mine.
I have become a Mustanger.
XRtowcar is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2022, 09:14 AM   #12
Vesper Martini
I see a few comments on that, but no one with actual wheel damage, but still worth checking so Ill ask what temperature his system goes to. I believe some are not that high
Old 01-04-2022, 09:21 AM   #13
Vesper Martini
The wheels are in great condition, Ill give them a good clean after the tyres are removes as the is a bit of brake dust build up in the groves
Old 01-04-2022, 06:39 PM   #14
Check out youtube
[B]BTW white is the new black
[/B
Just for you Cav..................
DFB FGXR6 is online now   Reply With Quote Multi-Quote with this Post
