Old 10-11-2021, 01:18 PM   #1
Maggotchops
Default 2007 Focus CL Tail/Brake light issue help please?
Hi, hoping to get some help with the tail/brake light issue on my 2007 Focus CL please.
Day time driving all brake lights work as they should (including the top centre brake light) All indicator lights work fine.
Night time driving the tail lights work fine however when the brake is pressed the top rear centre brake light engages, however the left & right tail lights completely go out and the brake lights do not engage? (there is no rear lights apart from top centre brake light)
I have checked all the globes & the light housing connections seem fine, fuses are all fine. I also checked the rear number plate fuse and lights as I had heard it may be linked by means of grounding the brake lights but they fine also?
How can they work during the day but not when the head lights are operational?
Any ideas help would be appreciated
Maggotchops is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2021, 02:35 PM   #2
11ford11
Default Re: 2007 Focus CL Tail/Brake light issue help please?
Indicates a earth problem to the lights
Check for a loose or burnt common earth point in wiring at rear or run a temporary wire between globe holder earth connection and body
11ford11 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2021, 02:37 PM   #3
marg99
faulty earth works that until you add the tail and brake lights to the demand. 11Ford11 is correct
Old 10-11-2021, 05:07 PM   #4
Maggotchops
Thanks for the replies. I will check the wiring, it did seem to look ok? What exactly should I be looking for in grounding issue? Im not really sure what colour the earth wire should be? Appreciate the responses.
Old 10-11-2021, 05:33 PM   #5
marg99
find where the ground is bolted/screwed to the body unscrew it clean the area so it clean metal and reattach.most likely in the trunk area Usually they are black wires.
Old 11-11-2021, 07:16 PM   #6
11ford11
Black wires
Screwed to left and right side of luggage compartment
about half way back and half way up check any black wires connected to the body work in this area
Another location to check after this is under the front door scuff plates screwed to the sill
Did you try connecting your own wire to the ground wire of the lights and screwing it to earth
Old 12-11-2021, 07:21 PM   #7
Maggotchops
Thanks for the reply everyone, have not been able to check the ground issue yet. Yesterday my daughter got stuck at the lights with no way of changing gears, clutch pedal flat to the floor. Long story short got towed to repair shop and now quoted 2-3 thousand to fix a clutch cylinder! Only just found this out 5 minutes ago. Needless to say the lights may take a back seat for now!? 🥲
Old 12-11-2021, 07:58 PM   #8
marg99
the slave cylinder is inside the bell housing so its a big job and probably should replace clutch at same time
Old 14-11-2021, 09:29 PM   #9
Maggotchops
Hey thanks again for the help. Is 2-3.5 thousand around the mark for this kind of repair work? Not sure if it’s worth ringing a few other places first although it’s already been towed to the mechanics. (Who I believe to be fair) ? Cheers again
Old 15-11-2021, 11:13 AM   #10
Rs31markie
Hi, be careful if you just replace the clutch. That model (I think)has a variable mass flywheel. I changed mine and bought a kit complete with solid flywheel think it was around $900.
Rs31markie is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2021, 03:17 PM   #11
Maggotchops
Hi folks, apologies for the absence.
My daughter had a conversion kit from dual fly wheel to single installed on the vehicle, did the whole clutch & now have it back. (Bit tight coming into Christmas hence the wait)
Now I will get a chance to look for the ground to address original post lol
Thanks I’ll update when can 👌🏼👍🏼
Old 10-12-2021, 03:36 PM   #12
Maggotchops
Originally Posted by 11ford11 View Post
Black wires
Ok thanks, I’m looking at all the great plastic panels in the luggage compartment thinking I might just take it to a auto electrician. Thanks for the help 👌🏼
Old 11-12-2021, 10:34 AM   #13
11ford11
Put your own earths to the light sockets by adding a piece of wire onto the earth wire (black wire normally) near the sockets and attaching under a screw or bolt nearby
Old 13-01-2022, 04:46 PM   #14
Peterlcbj
Its more than likely inside one of the bulb holders itself . I had a similar issue . the wiring between where the plug connects and the light slots in is not one continual wire, its two pieces. It could be they are arcing /shorting causing your issue.
https://www.youtube.com/watch?v=oK7l...iedPerformance
Peterlcbj is offline   Reply With Quote Multi-Quote with this Post
