Old 15-10-2021, 11:39 PM   #1
FXD302
Default Oil sender switch
Hi All,
I have an XD GL wagon, had a 6 now a 302 clevo.
I want to change the instrument cluster to a sports cluster.
Do I need to swap out the existing oil sender switch which was for the low oil level light to suit the oil pressure gauge on the new cluster?
Cheers.
FXD302 is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2021, 12:11 AM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: Oil sender switch
Yes, you'll need an oil pressure sender unit
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2021, 10:45 AM   #3
11ford11
If Clevo is currently working a light -sender will require charging to one that suits a gauge
11ford11 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2021, 12:34 AM   #4
FXD302
Thanks guys I will chase one up, any preferences or are they all alike?
Old 17-10-2021, 09:07 AM   #5
foxtrot3
foxtrot3's Avatar
Hi. It could have one of 2 different oil pressure gauges in it. An XD cluster used a 73-10 ohm sender(360-003) and the XE cluster used a 10-180 ohm sender (360-013). At around $100 a hit the best thing to do is hook up the cluster with the sender wire disconnected ann with the key on see where the needle points, then earth the sender wire and see what way the needle moves. If it goes up it needs the XD sender, if it goes down it needs the XE sender. You may need to get the tacho calibrated as well as a lot of those clusters were used in 6 cyl cars. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
