Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
26-08-2020, 09:32 PM | #1 | ||
When up grading a 2004 BA falcon to 6/4 brembo calipers do you need a FPV master cylinder to operate them properly or even a different booster???????
GIMME FUEL, GIMME FIRE, GIMME THAT WHICH I DESIRE. ---------------------------------------------------------------- BA falcon XT mkII, 5.4lt, 5sp, Y-code, xy windowless pano, 3 on the tree manual. re-shelled xy falcon GT, manual. 1980 honda CX500 scrambler/dirt tracker |
27-08-2020, 01:05 PM | #2 | ||
I beleive the master cyclinder in the FPV's was the same as a regular falcon. I also have the parts to upgrade to 6/4 brembos, just need the time to change it all over.
I am curious if a change is required for the master cylinder. |
27-08-2020, 08:29 PM | #3 | ||
When I first put them 6/4 brembos on this BA XT falcon they work great but for a while now they don’t seem to bit as good and I’m getting the ABS come on at random times mostly at light pedal input????.
I understand my cars ABS is tuned for a stock braking set up.... but it never used to do it so just asking in case I need to bring other parts up to spec Anyone got ideas on the ABS coming on??
27-08-2020, 10:42 PM | #4 | ||
There were different boosters and master cylinders in BA to BF series but had nothing to do with Brembos or standard brakes. It was more to do with if you had ABS, DSC, traction control etc.
27-08-2020, 10:53 PM | #5 | ||
BA/F6 BF/F6 SSV/R TTG
FPV have different master cylinder for brembo combo. Its the crack pressure difference between front and rear.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
28-08-2020, 08:51 AM | #6 | ||
Below are all the combinations of brake master cylinders for BA to BF Falcon including FPV..
BA BF Brake Master Cylinders.JPG |
29-08-2020, 12:21 AM | #7 | ||
15-10-2020, 06:33 PM | #8 | ||
06-11-2020, 11:27 PM | #9 | ||
i ended up fixing my issue i had some metal shavings on one of the sensors cleaned them up and all good now
