27-07-2020, 09:59 PM | #1 | ||
Hey guys I’m new to the ford seen I have just brought my son his first car it’s a 1998 Ford Festiva 3 I’m looking if someone has a workshop manual for this car and could you please tell me if the rear wheel bearings needs to pressed in ? Any help would be good I have searched everywhere for the info and workshop manual and can’t find anything anywhere
28-07-2020, 03:40 AM | #2 | |||
Where to next??
Can't help you with the workshop manual. If it's the 1.5L you got hopefully its the 16v model. They had a short run of 16v twin cam engines in 97-98 and you could really feel the extra kw. Sadly in 99 they didn't feel so generous and went back to the lower output 1.5.
28-07-2020, 09:58 AM | #3 | ||
The wheel bearing in the drum are just a cone type bearing where you need to punch the cone out, then do up the nut with some pre-load similar to early Falcon front wheel bearing. The nut also is LH thread and you need to punch the end of the nut into the locking position when the preload is set.
28-07-2020, 10:20 AM | #4 | ||
Thank you very much for the info on the rear bearings and it’s WF Festiva glxi hatch if that’s any help to tell me if it’s the 1.5l or not And it’s so hard to try and find the workshop manual it seems that no one has it
28-07-2020, 11:03 AM | #5 | ||
Limited supply
you can always look for the mazda equivalent, mechanically they are the same, I believe
28-07-2020, 11:23 AM | #6 | ||||
Although it has a Mazda derived motor, it's more a Kia than a Mazda Quote:
regards Blue Last edited by aussiblue; 28-07-2020 at 11:30 AM. |
28-07-2020, 11:24 AM | #7 | ||
28-07-2020, 11:36 AM | #8 | |||
28-07-2020, 11:48 AM | #9 | ||
Very easy to do, below is the image of all the components. Have you done front wheel bearings on a pre AU Falcon, because it is very much the same process. I have the workshop manual, just trying to find it so I can get you the instructions rather than writing them step by step.
And yes the vehicle is Kia not Mazda based. You should see Kia on the ID tag on the firewall. WB Festive Rear Wheel Bearing.JPG |
28-07-2020, 11:50 AM | #10 | ||
Private Message Franco Cozzo as he says he has a WF Festiva workshop manual in this thread https://fordforums.com.au/showthread.php?t=11400655
regards Blue |
28-07-2020, 12:02 PM | #11 | |||
28-07-2020, 12:31 PM | #12 | ||
Hard to scan as the book is thick on the scanner.
Hopefully you can make it out... WB WF Festiva Rear Wheel Bearing Replacement.pdf |
28-07-2020, 12:55 PM | #13 | ||
Chairman & Administrator
I have the manual for the 1.3L but not the 1.5L.
Observatio Facta Rotae
28-07-2020, 12:56 PM | #14 | |||
28-07-2020, 07:43 PM | #15 | ||
28-07-2020, 09:39 PM | #16 | ||
29-07-2020, 07:59 PM | #17 | ||||
Where to next??
12v, 57kW and 115Nm if I recall? That's what mine had. Shame they never kept it till the end - drove the 98 model with the HO engine and it bloody flew compared to mine. 16% more power and torque
29-07-2020, 08:02 PM | #18 | |||
29-07-2020, 08:06 PM | #19 | |||
Where to next??
I tried to do the diesel filter on my i30 and gave up - it's well buried below lots of tubes and wires, need to remove this, loosen that etc.... Why??
29-07-2020, 08:10 PM | #20 | |||
29-07-2020, 08:17 PM | #21 | |||
Where to next??
B13 (1.3) and B15 (1.5) were the letters they used. It would also say it on the rego papers as their CC equivalent.
29-07-2020, 09:05 PM | #22 | ||
29-07-2020, 09:19 PM | #23 | ||
Where to next??
That seems odd? What state are you in? In NSW rego papers state engine capacity.
29-07-2020, 09:57 PM | #24 | ||
29-07-2020, 10:00 PM | #25 | ||
Where to next??
Ahhhh B3 and B5 that's right! Not B13 and B15...
Its been a while.
29-07-2020, 10:07 PM | #26 | ||
29-07-2020, 10:17 PM | #27 | ||
Where to next??
29-07-2020, 10:27 PM | #28 | ||
