Old 08-07-2020, 01:49 PM   #1
Tonz
Default FG2 lower grill repair
Has anyone tried plastic welding the lower grill.
I am dreaming up an idea with the lower grill, it would require a flat plate at rear of grill and strong welding
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2020, 07:55 PM   #2
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Default Re: FG2 lower grill repair
It will work until the next time you scrape or hit the bumper too hard.
Which in my taxis is the next day...I prefer pop rivets and zip ties.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2020, 08:29 PM   #3
Tonz
Maybe I need to clarify my plan/dream.
i hope to cut 2 circular holes each side of black lower grill, then glue/weld whatever a horizontal plate on inside to hold a 7" driving light poking through.
the plate may need to be braced vertically, fine I figure plastic welding would be a lot stronger than gluing.
Old 09-07-2020, 03:51 AM   #4
Nicholas11
I'm completely confused
Nicholas11 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2020, 03:51 PM   #5
mad2
Regular...with metamusal
about?
wants to add 7" driving lights to front bumper. simples
mad2 is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2020, 04:16 PM   #6
Tonz
paintshop is not one of my friends but this gives an idea.
I currently have a lightbar sitting just above the grill and it looks carp so thought this might be an idea.
Old 09-07-2020, 08:24 PM   #7
Jastel
I had a car with spotties on those cheap number plate brackets, and I found they shook too much on anything but the smoothest new road...I think they really need to be mounted to a solid place like the steel crossmember. The black grill is only held in by clips.
I have seen people put a light bar inside the top grill....a solid mount to the steel crossmember or maybe the hard plastic...not sure how the light looks with the grill and Ford badge across it? Or if there are cooling issues?
Old 09-07-2020, 08:32 PM   #8
Tonz
thanks mate, I was having a poo peep again and hopefully I can mount a metal bar in front of radiator yet still behind lower grill, mount lights to that bar and cut appropriate holes in said grill.
Will be in Adelaide soon, so chat to my Favorited dismantler people and get their view.
Old 10-07-2020, 08:53 PM   #9
Jastel
So long as the metal bar is fixed to a solid bit and not the plastic grill it should be OK.
Another thing is the lower down they are, it seems the more chance of getting hit by a rock...have busted several XR6 type foglights...one was by a bloody bird!
Old 10-07-2020, 08:57 PM   #10
Tonz
come live where I do, sheep, foxes (yes gotta ya bas****) not many roos at present , tree limbs falling at dusk.
Old 22-07-2020, 05:11 PM   #11
Nicholas11
sehr interessant! jetzt mal sehen, was hier ist
Old 23-07-2020, 06:27 PM   #12
Nicholas11
:d:d:d:d:d:d:d:d:d:d
