Hi there, i'm just wondering if it is possible to spray a car, all with aerosol cans and get a half decent job? thanks
. Last edited by Raptor; 12-05-2020 at 05:10 PM. Reason: A name for the thread Paul, not your name ;-) |
You can actually.
You spray a panel, then sand it back, spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand,spray, sand, spray, sand. When you've finally got a reasonable finish, move on to the next panel. |
LIFELONG DJR SUPPORTER
Ive seen a yellow VC Commy slowly morph into a pretty tidy Midnight Blue. Was pretty god outcome for a rattle can job on a car being used to deliver Pizza every day.
But yeah, 1 panel at a time I recall lol
I have a compressor and gun, i have a small elec hand held jobbie too, not that i've ever tried to paint , haha, the reason i wanted to try cans is that i could remove and do one panel at a time, on stands, it will take me days to do each one, then i could undercoat then paint them as i go, and i wouldn't have to keep cleaning the gun and wasting paint. for a panel at a time, i really only need to do a same colour, closed door spray, Just for the RWC and Rego.
#9 | |||
Where to next??
Check out YouTube, bound to be several videos / tutorials on how to do it and the outcome expected.
#12 | |||
Cabover nut
5 users like this post: |
CLEVO POWERED
Have actually painted a car in Enamel with brushes. Once sanded, which took ages due to all the brush marks, didn't come out too bad. It was white and would pass any 10 foot test with ease.
#14 | |||
Cabover nut
#18 | ||
Yes.
If you use acrylic and just plaster it on, any dryness or peel will sand out easily and buff back to a shine. Similar to the brush jobs done many times. However, you will use so many cans, and it will be such a long, tedious job, youll wish you didn't. Also will be very expensive if you get cans mixed to your colour. Get yourself a cheap $30~ pot gun for primer only, dont have to clean it that well. Repair all your bolt on panels, then shell out for the $90 gravity fed and paint the whole car in one hit. |
#19 | ||
No.
Problem with spray cans is the limited pressure that comes out of them. You need really short strokes with a spray can because the pressure isn't steady. If you have a tub of hot water, 10 spray cans in it, shake-spray, switch can, shake-spray etc it can be put on fairly even, but you'll have to sand it so much you could have saved money and just brushed paint on anyway. You'd have spent so much you could have bought a second hand compressor and gun and actually had more control of the air pressure and needed to sand less. |
#20 | ||
Good old rattle can rebuild
My mate did his old ute once, cost more in cans than the ute was worth
Had EB XR8 AU XR8 220 (awsome car ) AU Fairmont BA MK2 XR6 Turbo Now XDUB |
#21 | |||
#22 | |||
![]() But yeah, that was the first time I've seen whole cars done with spray cans, so that's why I know they never come out good. Let me know if you're still out there Brad from Pad, the mad max fan.. ![]() |
#23 | ||
Cabover nut
#24 | ||
![]() Join Date: Oct 2006
Didn't Ed China do an Escort with rattle cans in an early episode of Wheeler Dealers?
regards Blue |
#25 | ||
Thanks for most of the replies, I am not a teenager, wanting to do a show paint job with $10 spray cans. the reason I asked is because the car isn't up to having a professional paint job, as the next owner will likely strip and resto. I have compressor and guns, and money isn't an issue. but having lung fibrosis and cancer, I can only work for 10 mins before I need a half hr break to breathe. So I would be forever cleaning guns and jets. The only limitation I have is time, i had a thread where i was restoring her, but got sick and it's been sitting for yrs now. So i just want to get it on the road and drive her for a while. i have finished the interior. so i'm not worried about it looking flash, just good enough to be registered, because i want to have some fun in her, while i still can. and as for devaluing the car, rubbish, whatever it is painted with will need to be stripped eventually.
4 users like this post: |
#26 | |||
Cabover nut
#27 | ||
Experienced Member
My very first car I painted with aerosol paint cans, came up looking real good for an old car in those days, just don't expect what a proper professional respray job will give you.
Just make sure your prep work is done properly. |
#28 | |||
Right now I'm doing a bumper and trim touch up and for the gloss black I just used supercheap paint and it was terrrible. The stream kept cutting in and out going from dry to runs. I had to spray a 2 inch wide strip back and forth horizontally in 50 strokes to get a wet cover but with no dry and no runs. I'm touching up the colour with a proper colour matched can from the paint shop and it has better pressure, but you get what you pay for because that small can cost $37! So you'd be paying a lot - a hell of a lot, for high quality paint in high quality spray cans, or suffering with the terrible output of cheap cans. I already regret being too lazy to get my gun out, but my compressor is very very tired and I've broken the separator/drier when ripping it down and moving house and losing my workshop. I'd rather buy 10 litres of thinners and put it in a bucket to throw the gun in and chuck a lid on between the times you can do the job with a gun if you already have the gun and a good comp, reg and filters. It's much easier to have a control with a gun and set it so paint flows evenly. Less sanding work which would be of benefit to you. Last edited by oldel; 13-05-2020 at 04:31 PM. |
#29 | |||
#30 | |||
i guess it will have to wait a bit until i find someone. no rush Thanks |
