Old 03-03-2020, 03:40 AM   #1
Default Ten Worse Brake Pictures
You have to wonder about some of the drivers:
http://www.safebraking.com/top-10-bad-brake-images/
Old 03-03-2020, 07:38 AM   #2
Tassie f100
Default Re: Ten Worse Brake Pictures
I did a job on an old farmers Hilux years ago where the pads were completely gone,and the pistons had a fair bit worn.The solid disc was worn to about 3 mm.I asked if he had heard the metal to metal and he said,well I did hear a bit of noise but thought it was just a stick caught up and rubbing on something.The only reason he decided something was wrong was when the brakes stopped working, because the pistons came so far out of the calipers they started leaking and he ran out of brakes
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2020, 09:37 AM   #3
I had a friend buy a used car in the 70's and when we went to replace the brake pads we found the previous owner had used shaped pieces of jarrah wood to replace the pads. They sort of worked OK but it answered the question of why the car took a while to stop and there was smoke and burning smells coming from the front wheels. Googling it suggests it was perhaps not so uncommon for dodgy sellers and even dealers.
Old 03-03-2020, 10:25 AM   #4
Way back in 1972 I bought a Valiant VE station wagon from a major dealer. It was sans engine. I put my hot 225 slant six in it and it screamed. It seemed to stop pretty well too. Discovered later on that it had no rear brakes. The drums were there but nothing else. Oddly enough after we gave it some rears it didn't seem to stop any better.
Old 03-03-2020, 10:32 AM   #5
Mechan1k
Mechan1k's Avatar
Had a sticking piston recently on the FG.
Doesn't take long for the pad to wear diagonally.
But you really notice the lack of braking performance though as it's really only using half the braking force .... plus the shuddering is bad enough as well.
Old 03-03-2020, 11:24 AM   #6
Tassie f100
Actually I had a similiar experience with another customer car,which also happened to be either a VE or VF Val wagon,but with this one the drum had worn to the point where the face of the drum and the drum part were separate,so the brakes were all there,but didn’t do any thing on that wheel
Old 03-03-2020, 01:25 PM   #7
Well they wouldn't wear out then.
Old 03-03-2020, 01:46 PM   #8
Tassie f100
You are right LG17, guaranteed million kms out of rear brake shoes
Old 03-03-2020, 03:37 PM   #9
roKWiz
Cabover nut
roKWiz's Avatar
Love the pic of the disc calliper hanging from it's line under the rear.
The ol Kenworth has dry road and slippery road front brakes, basically front brake on front brakes off valve.
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2020, 08:01 PM   #10
Sounds like an old wog mechanic trick.
Old 03-03-2020, 08:12 PM   #11
jimbo51
If it's working as designed it allows either 100% or 50% of applied air pressure
jimbo51 is offline   Reply With Quote Multi-Quote with this Post
