Old 10-10-2019, 12:15 PM   #1
cat007
Default Dyno tune prep
Hi all.
I've pulled the trigger and booked my car in for a tune next month.
Just wondering if there's anything I should be doing before the tune?
Plugs are OEM Ford ones and gapped to 1.1mm about 5k km ago.
Engine oil changed about 1500km ago.
Power steering fluid (through a failure) is brand new.
Trans fluid (ZF auto) changed around 10k km ago.
Air filter is K&N and will be cleaned closer to date.
Anything I should do in preparation for it?
cat007 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2019, 01:02 PM   #2
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
Default Re: Dyno tune prep
Are you changing any parts. How much boost you aiming for. If above 10psi fit a set of bf lpg plugs from Ford. They are gapped factory at 0.7 and cost $60 for 6
https://www.ebay.com.au/itm/LPG-SPAR...wAAOSw1CBbz~kq
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2019, 01:17 PM   #3
Bossxr8
Peter Car
Bossxr8's Avatar
Yeah I was going to say gap the plugs to 0.7mm.
Also fuel filter?
Old 10-10-2019, 01:27 PM   #4
arronm
arronm's Avatar
Yeh fuel filter if it's more than 50k old. Gapping from 1.1 to 0.7 leaves a bad angle for the electrode. Plugs have to come out so may as well replace with new ones
Xtreme Ford Tuning
Old 10-10-2019, 01:52 PM   #5
cat007
Thanks.
Ok new 0.7 plugs ordered.
Car is at 105k's and fuel filter was done about 20k's ago.
Cheers!
Hunt
Old 10-10-2019, 01:55 PM   #6
Peter B - CV8
+ fresh fuel.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
