Old 22-04-2019, 03:17 PM   #1
Christon
Default Electrical problems Ford Mondeo 2009 MA TDCI Diesel Auto
I've posted about this a few times now, however after seeing yet another person about it during a routine service, I have some more information.
So basically around 6 months ago now I bought a 2nd hand Ford Mondeo 2009 privately for $5000. It was an ex Uber, the only thing wrong with it was the cruise control didn't work.
The first thing I did was take it to service the airbags as I found it was part of the airbag recall, after doing this, the cruise control was working flawlessly.
I then decided I wanted a aftermarket radio in it so I bought a cheap one from eBay that fitted the Mondeo nicely and had it installed by a nearby Car Audio place for $170ish. Very similar to this one: https://www.ebay.com.au/itm/7-Car-CD...frcectupt=true. The car audio guy warned me that these "chinese brands" occasionally don't supply the right harnesses but they will try anyway.
Lets just say the place seemed apprehensive to install it, but I assumed it was because they wished I bought one of their $1000 head units instead of my own, they certainly didn't give any further information beyond the harness thing.
Anyway as the job was nearing completion, the place rang up and advised if I knew the engine malfunction light was on. I was 80% sure it wasn't on before I took it there, but I figured maybe I'd not noticed or maybe it was coincidental. Nonetheless I figured it was probably something minor and proceeded back to the place to the car up.
After picking up the car I was very happy with the radio, it fitted nicely and seemed to work great. The check engine light was definitely on, and I proceeded to notice a bunch of other electrical's were no longer working, most notably the cruise control, but also the heated seats and also the air conditioner.
I took it to AutoBahn nearby my place who told me the following two fault codes:
P003A17 - Turbo / Supercharger boost control
P212100 - Throttle pedal position switch circuit range error
They mentioned there were other fault codes, but for now, these were the main ones.
They told me the Intercooler hose was soft and leaking and was the first thing that needed fixing and would cost $650.
I decided to save up and drive the car as is and get a second opinion when it's due for it's next service. Which I very recently did.
I should note that during this time the car ran fine outside of the issues already mentioned, and still is running fine, however the second mechanic gave me alot more information than the first did.
He said the intercooler hose was fine. He noted the throttle pedal position error, also the radiator fan was not spinning the entire time he performed the service (I've monitored the temperature since however and it doesn't go above halfway). He proceeded to read out to me maybe about 10 - 15 fault codes and mentioned a bunch he cleared off.
He had a look at the air conditioner and said there's a full tank of gas but it's not communicating with the control unit.
At this point I was confident potentially all my issues were electrical and all started when I had the radio replaced or at least most did. Well the engine malfunction warning didn't start until the radio replacement, and it's still on now.
Well, I changed the radio back to the stock radio and plan to not use the cheap one from eBay again, I may sell it probably. This didn't fix any issues, which I've assumed is because the damage was already done. So I proceeded to check all relevant fuses, under the bonnet, centre, and rear of the car, the ones I checked seemed fine. Beyond these things I can only assume it's some blown fuse or wire or something somewhere caused by the radio. I'm not an electrician, but based off what I can assume maybe the cheap aftermarket radio caused a short circuit, or was draining too much power, causing electricial problems elsewhere. The only other alternative is the people who installed it cut a bunch of wires for fun... but I'm no expert, and I had a good look behind the head unit when I replaced it.. it all seemed fine to me.. but what do I know I guess.
I mean, it sounds like mechanically the car is fine, certainly the last mechanic I saw seemed to think this, and even said it was a good car, other than the long string of electrical problems that seemed to all start when I had some car audio company put an aftermarket eBay radio in my car. Like at this stage, I'm pretty used to not having cruise control or air conditioning, which are the main things I kinda wish I had at this point. I'm just so darn curious as to what is causing all of these problems, because I seriously don't think it's a bunch of little issues strewn throughout the car, I think it's some centralized problem happening somewhere causing a bunch of little issues.. once again I could be completely wrong, but I can't afford to get all these little issues looked at.
I can only hope someone in these forums might know where I can start, what may be causing the problem, what I could do to fix it. I'm not afraid to try things myself, nor am I afraid to take it somewhere and pay provided I know it will fix the problem/s and not just be another investigation.
Any help would be greatly appreciated!
Christon is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2019, 10:47 PM   #2
cobrin
Challenge Accepted!
cobrin's Avatar
Default Re: Electrical problems Ford Mondeo 2009 MA TDCI Diesel Auto
You need to check all fuses.
The Mondeo only has one fan, it has multiple speeds but I believe the Fan Speed Controller is a weak point, I've replaced mine as it failed and it were $780+fitting. It's expensive because the controller is part of the fan assembly and cowling so you can see where the cost rockets, you can't separate them. That were from Ford going back '15.
If your fan doesn't work from the moment you turn on the AC I'd be looking into the fan controller (well auto lecky). Sort that out first it's more important if the fan is faulty.
P003A17 Turbo blocked by soot or not able to adjust, that or the vane position sensor seems to be the likely culprits.
P212100 well you know that one so you'll need to have it checked/replaced.
Good luck hope it works out to be cheap fixes nonetheless.
Undecided replacement...
[SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD]
cobrin is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2019, 08:16 PM   #3
Mondaveo
Mondaveo's Avatar
Most OBDII scan tools only read the standard HS-CAN communication bus. Many Ford & Mazda vehicles (pertinent for our case, Mondeo) have a secondary bus called MS-CAN.
Most engine-related DTCs should be exposed through HS-CAN, but I've read that MS-CAN links the Body Control Module and infotainment, so it might turn up confirmation to your theory that a fault exists in something centralised that's thrown other things out.
Do you happen to know if either of the mechanics you consulted were reading codes off both HS-CAN and MS-CAN interfaces? If not, an OBDII scanner and FORScan software is pretty inexpensive in the scheme of things, and it may be worth equipping yourself if there could be more than one problem to chase down. Look for an adaptor/dongle that can read MS-CAN as well as HS-CAN, I like the OBDLink brand but there are cheaper options available.
Just my suggestions, if it were me I would be chasing more data to get a better idea what's going on.
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2019, 05:45 PM   #4
Christon
Have ran an OBDII scan tool through and taken screenshots of what it says.
Here is the link to the screens: https://photos.app.goo.gl/4qBYjTiNFPViLvnM9
It was a pretty cheap scanner so maybe I should've bought a more robust one that gave a bit more info or something?
Any ideas?
Thanks!
Old 08-06-2019, 07:01 PM   #5
rondeo
Problem could be with the GEM and/or associated connections.
You could ask Ford if they can check the GEM.
You can't test the GEM with ordinary scan tools.
This gives you some idea what the GEM is involved in.
https://workshop-manuals.com/ford/mo..._module_(gem)/
According to my information it's involved in the air con controls 'partial' it says.
rondeo is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2019, 10:24 PM   #6
Christon
Thankyou, I think at this stage, that may be the next step in this process. Will enquire with them.
Old 09-06-2019, 10:53 AM   #7
rondeo
I forgot to mention:
You can see PIDS and DCTs in the GEM with Forscan.
You need an OBD adapter which supports HS and MS CAN, such as the OBDLink MX bluetooth and Forscan app on the phone, or a laptop.
That might at least show if any GEM modules are upset.
The GEM shows as BCMii in Forscan.
