Old 20-02-2018, 04:49 PM   #1
jetboat
Default speed sensor for ba 6
hey can any one help me. ive got a ba 6 in a jet boat running standard car computer which i got from a guy in ausie that he has flashed it and taken out security stuff. Ive had it running in the boat and runs great but i get to a point where the computer goes into limp mode. so have rung guy in ausie and he has said that i need to put a speed sensor onto the vss terminal on eec-b07.
so my question do i take power for sensor from battery or do i need to to get the supply from some where else on the computer.
hope some one can help.
cheers steve
jetboat is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2018, 06:43 PM   #2
Tonz
Default Re: speed sensor for ba 6
your in New Zealand?
Is yours a Hamilton Jet boat?
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2018, 10:47 PM   #3
baboon
Contributor: For members who make a contribution worthy of recognition. - Issue reason: went to the trouble of posting up some great Vids of the AFF drag meet
According to the workshop manual the vehicle speed can be taken from the output shaft speed sensor in the transmission housing.
PCM pin B7 - Vehicle speed signal VSS
PCM pin B45 - Vehicle Reference Voltage (VREF)
PCM pin B33 - Signal Return (SIGRTN)
Good luck.
baboon is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2018, 05:30 AM   #4
jetboat
great ill give that a go. yes im in nz and yes its a hamilton jet boat. its an older jet 44..
Old 21-02-2018, 12:47 PM   #5
Mercury Bullet
Id love to see a barra T in a boat. Straight pipe ftw.
It would shame many a 350.
www.bseries.com.au/mercurybullet
2016 Falcon XR8. Powered by the legend that is - David Winter.
XC Cobra #181.
1985 Mack Superliner, CAT 3408, 24 speed Allison.
Mercury Bullet is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2018, 12:58 PM   #6
jetboat
yes mercury bullet my brother and i have discussed that and are quite keen
Old 21-02-2018, 02:24 PM   #7
baboon
Bullet Performance Racing have a project barra turbo jet boat shown here:
BPRacing are working on a barra turbo boat project
BPRacing has successfully sparked life into the jet boat project
Today BPRacing have some fun on the water at Barwon Heads tuning the 4.0L Barra turbo in steves boat.
Pretty awesome!
Old 21-02-2018, 05:02 PM   #8
jetboat
ok so ive had a look at the b connector on the ecu. still a bit confused. another thread ive read under ecu on this forum said b7 is the signal in. im confused on which supply do i take to power up the proximity switch.
sorry if im slow on the pick up.
cheers for any help
Old 21-02-2018, 05:52 PM   #9
baboon
Your sensor will have 3 wires, 1 wire is for the speed signal from the sensor into the pcm.
The second wire will be power, the third will be return/ground wire.
So from above
B7 is signal from the sensor into the pcm
B45 is the power supply from the pcm to the sensor (could be 5V or 12V not sure use multimeter to test)
B33 is the signal return/ground from sensor to pcm.
Good luck.
Old 21-02-2018, 06:02 PM   #10
jetboat
thanks mate that makes sense
Old 24-02-2018, 05:55 PM   #11
jetboat
ok ive got it to work. I used a 12v proximity sensor hook it to + and - battery and used the signal back into b7 and it comes up with a speed so going to test it on the water.
Old 24-02-2018, 06:01 PM   #12
Mechan1k
Mechan1k's Avatar
Eagerly awaiting video
