28-11-2017, 08:38 AM | #1 | ||
Au Falcon = Mr Reliable
28-11-2017, 12:31 PM | #3 | |||
Sling Shot
Awesome car! I love how clean and simple the engine bay is. And seemed extremely reliable! The Falcon 6 was such an amazing engine.
28-11-2017, 02:32 PM | #4 | ||
Peter Car
28-11-2017, 03:19 PM | #5 | ||
28-11-2017, 08:52 PM | #7 | ||
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
28-11-2017, 09:02 PM | #8 | ||
28-11-2017, 09:15 PM | #9 | ||
Wouldn't have a clue.
Much bigger turbo on the f6 though. A longer duration cam won't help, all that will do is leak boost.
28-11-2017, 09:20 PM | #10 | ||
F6 also has slightly lower compression so a different piston.
Allows moar boost.
28-11-2017, 09:26 PM | #11 | ||
29-11-2017, 06:22 AM | #13 | ||
Hmm, I think xr6t 4lb and f6 9lb.(bseries)
-Bionic BF2 XR6T 350+rwkw@17psi,Pulsar 3582, Leather,premo sound-now with Aerpro + JVC KW-M785BW. Plazmaman IC + hot & cold side, Walbro fuel pump, Turbo side intake, CES 3.5 split + Ultrex SS exhaust, deka 60 injectors, earls turbo oil feed. DBA T3 & Akebono ProACT all round, Whiteline sway bars,nolathane bushes, Koni reds,Kings springs,nolathane camber kit,whiteline bump stops. Built tailshaft + billet cv, ZF + PWR exchanger + braided lines, Superpro diff bushes. |
29-11-2017, 08:24 AM | #14 | ||
Are the turbo Barra motors a significantly much heavier engine compared to the stock motor it replaces in a X, E & A series conversion?
Anyone got any hints, tips or info for those thinking of doing the swap into their Falcon? After looking at this thread, there may some members & guests quietly considering doing the swap lol!! cheers, Maka
29-11-2017, 10:56 AM | #15 | ||
At only 1380kg less the original motor the XD would probably be shaking in its boots with a turbo Barra goin in Love the XD, awesome childhood memories in the old mans XD 6 cylinder. Would be good to see the ‘doc’ and go back in time with the F6
29-11-2017, 02:43 PM | #16 | ||
Peter Car
29-11-2017, 02:54 PM | #17 | ||
Copied and pasted off Wikipedia, love it .............
Barra 270T FG Edit This engine is found in the FG/FG-X Falcon XR6 Turbo, and was produced between mid 2008 and late 2016. Although the power figures for the revised turbo engine for the Barra 270T FG mimic the old FPV turbo I6, the engines are quite different. It has a redesigned low-profile intake plenum (replacing the circa 1994 broadband manifold intake which originated in the naturally aspirated EF Falcon), a smaller turbocharger which can spool faster, an new intercooler, and also a modified cylinder head to increase compression. The end result is that the FG XR6 Turbo is actually faster than the FPV's BF Typhoon although they share the same power output. This engine employs an transient over-boost feature for a maximum 10 seconds when optimal atmospheric conditions are met when under full throttle, boosting torque to 586 Nm.[8] However, there are claims that this figure is significantly higher than 586 Nm. Some sources claim over 640 Nm is achieved for 10 seconds. It is also rumoured that Ford under-quoted the Barra 270T FG's power figures, with Ford Engineers claiming that the actual power output is close to or over 305 kW. Numerous dynamometer printouts from various standard XR6s with the Turbo engine help to back up Ford Engineers' claims. Power: 270 kW (362 hp) @ 5250 rpm Torque: 533 N·m (393 lb·ft) @ 2000-4750 rpm Compression Ratio: 8.8:1 Barra 310T Edit This engine is found in the FG Falcon based FPV F6. It is the high-power variant of the FG XR6 Turbo's Barra 270T. It was produced between mid 2008 and mid 2014, ending production when FPV shut down. Featuring a larger turbocharger and intercooler, different pistons to reduce compression, and larger injectors than its less powerful sibling, it was the first engine manufactured in Australia to produce more than 100 hp (75 kW) per litre, producing 310 kW at the flywheel. It is rumoured that Ford under-quoted all turbo 6 figures to save face and to save the V8 models at the showroom when delivering the V8's power figures at the time. There are claims from Ford Engineers that say Ford under-quoted the F6's power figures, with numerous tests Australia wide that back up Ford Engineers' claims that the Barra 310T's power output is actually closer to 360 kW with torque exceeding 700 Nm. Power: 310 kW (416 hp) @ 5500 rpm[9] Torque: 565 N·m (417 lb·ft) @ 1950-5200 rpm Compression Ratio: 8.47:1 Barra 325T Edit The final and most powerful variant of the 4.0-litre I6 cylinder turbo-petrol engine featured in the FG-X XR6 Sprint. This engine is the most powerful six cylinder produced in Australia and was built in very limited numbers, and with only 500 for Australia and 50 for New Zealand (Actual production is 560, as there are 10 pre-production vehicles). Each engine had its own numbered build plaque attached to the rocker cover, which is painted in the same colour as the Territory Turbo rocker cover. The engine is based internally upon the Barra 270T, with extras added from the Barra 310T variant such as turbo, intercooler and injectors; and a custom designed carbon fibre air intake. It was chosen to base the engine on the 270T instead of the 310T due to the increased compression ratio. The engine employs an over-boost feature for 10 seconds when optimal atmospheric conditions are met when under full throttle, boosting power & torque to 370 kW and 650 Nm. Power: 325 kW (436 hp) @ 6000 rpm Torque: 576 N·m (425 lb·ft) @ 2750 rpm Compression Ratio: 8.8:1 |
29-11-2017, 05:08 PM | #18 | ||
I'll take the 325T FGX XR6 Sprint thanks!!!!
Those Torque numbers are nearly the same as alot of BIG litreage truck engines these days.....Geesus Christ!!!! The mighty Barra 4.0........Well done FordAU........... 'Six in a row' all the way for me.........FOREVER. I've owned about 8 Ford 4.0's since i was 19 and i love em to death! Last edited by GASWAGON; 29-11-2017 at 05:16 PM. |
29-11-2017, 05:14 PM | #19 | ||
Not sure what truck engines you're thinking of.
These days 2000ft/lb (not NM) is considered light on. HP is getting a lot closer, torque is night and day.
29-11-2017, 05:23 PM | #20 | |||
Totally different engine. I cant remember the N.M figures now but it was'nt far off what the 325T is putting out back then 20 years ago. Even back then we used to plug in the puta and you could set/program what HP figures you wanted just by punching in a few numbers. That was 20 years ago!!!. |
29-11-2017, 05:37 PM | #21 | ||
i think you will find the f6 is about 2000 odd nm less
29-11-2017, 06:07 PM | #22 | ||
O.k you are correct Jmack.
Go down the page and the NM figures are alot higher. Still not bad from Ford AU for a 4.0 car engine i reckon. https://www.cummins.com.au/wp-conten...R-brochure.pdf |
29-11-2017, 06:54 PM | #23 | ||
3 users like this post: |
30-11-2017, 05:24 PM | #24 | ||
According to Justin the pistons aren't any stronger, its cast exactly the same as the xr6t, the only difference is the top for compression reasons. And a different gudgeon pin to suit.
30-11-2017, 05:31 PM | #25 | |||
Way back when Volvo first released the F16 engine they were touting it's 2000+ ft/lbs of torque. We don't seem to have moved far in 20 odd years although horsepower has increased dramatically in comparison. The ISX looks like it's being torque limited by the puter.
30-11-2017, 05:48 PM | #26 | ||
Former BTIKD
Wasn't their 'signature' putting rods through the block
30-11-2017, 05:49 PM | #27 | ||
Well ye going by the chart you'd only rev to 1700rpm then change gears as it all drops off after that.
Realistically trucks only need mountains of torque to pull all the weight when taking off fully loaded. High KW is great but its the NM's that really do all the work. |
30-11-2017, 06:13 PM | #28 | ||
According to FPV's own website when it was active, in their own words, "the F6 pistons are a strengthened design" therefore they are indeed stronger, or if they're not why did they lie and say they are.
2013 G6E 2014 Territory Barra TS 23.5 Raptor 2016 R8 Clubsport Lsa sold for beer money F6 sold AND SAD ABOUT IT |
30-11-2017, 06:36 PM | #29 | ||
Not that i've ever heard but i left just as the Signatures came out.
I have heard stories of them being quite thirsty though??? A rebuild on a Signature is apparently about 60k these days!!! They used to fit them to Volvo's way back then and even these days there are some Macks getting around with them fitted too. |
30-11-2017, 06:42 PM | #30 | ||
Critical Thinker
Great video, just finished watching it. Love me a sleeper
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
