22-11-2017, 07:53 PM | #1 | ||
Hi all,
Just seeking some advice: Got my AUII Fairmont a transmission service today, and once I got home read on the invoice that the mechanic has used "ATF Dextron(sic) 3 Fluid". I was pretty sure the AUs need TQ95 or 95LE? Should I be heading back in the morning and sorting this out? Or is the Dex III fluid suitable? Cheers in advance!
Currently Garaged Mine: Sparkling Burgundy AUII Fairmont Sedan Mrs: Lightening Strike SZ Territory TS TDCI Dearly Departed 2006 SY Territory Ghia - Silhouette , 2000 AUII Wagon - Green, 2005 BA MKII Futura Sedan - Lightening Strike, 2009 FG XT - Ego, 2008 BF MKIII Wagon - Kashmir |
22-11-2017, 08:27 PM | #2 | ||
2009 xr turbo,2004 fiesta
No dexron will kill it,it must have tq95 and nothing else.
If he's been stupid enough to use dexron in it the trans will need to be flushed. |
22-11-2017, 08:42 PM | #3 | ||
Holy crap! I live about 5km from the place, should I be getting it towed?
22-11-2017, 08:49 PM | #4 | ||
Dex 3 is perfectly fine, except it must be Penrite, no other brand Dex 3 is compatible, Penrite has been designed with extra additives to make it compatible with BTR transmissions, serviced that many BTR's and used Penrite Dex 3 with no issues from customers.
I use Penrite Dex 3 in all my BTR, and have for the last 4 years. Check the brand, if Penrite, no stress, i'm not sure if any other brand has modified there Dex 3 to a similar composition to make it compatible however.
Current Car: 2002 AUII LTD 408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS Daily: 1998 Mitsubishi Super VR-4 Legnum |
22-11-2017, 10:25 PM | #5 | ||
First ive heard of it mcfly?
Ive used Castrol tq95 in my autos for over ten years and its made specifically for the btr 4 speeder,ill be sticking to it! The chances he used the same penrite as mcfly are minimal but fingers crossed... Just had a quick read of the dex 3 you are talking about mcfly and I wouldn't use it,its a multi vehicle ,I don't see how dex 3 is holden only and ford require a tq95 yet penrite claim to be good for both types of cars,there is a compromise on friction properties going on there,i would only be using tq 95 which is only made for the btr. Last edited by TICKFORD220; 22-11-2017 at 10:33 PM. |
22-11-2017, 10:30 PM | #6 | ||
Yep, can also be used in spruced up C4's too, its pretty versatile!
22-11-2017, 10:52 PM | #8 | ||
Nulon make ATF to suit Dex II/III and TQ95 as well. Haven't used it so can't comment how good it is, and I'm intending to use it in a T5 manual.
OP, when you talk to your mechanic, ask him what brand ATF he used, don't give him any choices, so he has to tell you instead. |
22-11-2017, 11:11 PM | #9 | ||
growing up is optional
23-11-2017, 01:09 AM | #10 | ||
Also see http://www.theoilman.com.au/wp-conte...ison-Chart.pdf for other BTR compatibles.
regards Blue |
23-11-2017, 01:13 AM | #11 | ||
You can also add this stuff to make your Dexron II compatible http://www.lubegard.com/~/C-251/LUBE...ersion+Formula .
Can be had on ebay https://www.ebay.com.au/itm/Lubegard...222504520196so if need be add this to the transmission.
regards Blue |
23-11-2017, 01:56 AM | #12 | ||
BA/F6 BF/F6 SSV/R TTG
It will be fine.
Full synthetics are best in gearboxes though. Manual and auto. http://www.datateck.com.au/lube/GulfWesternAus/
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
23-11-2017, 10:00 AM | #13 | ||
Au Falcon = Mr Reliable
I was in a similar situation recently, ring up Penrite & see if they guarantee their mv a/t fluid for use in your AU. If not put tq95 or equivalent in for piece of mind, good luck!
cheers, Maka
23-11-2017, 11:48 AM | #14 | ||
BTRE in their service training seminar materials, copies of which are floating around the internet, do warn that using other than TQ95 or approved equivalents may lead to harsh shifts, slipping in drive and premature gear failures. You would think the BTR engineers would know what they are talking about. I'd be putting the lubeguard in.
regards Blue |
23-11-2017, 11:59 AM | #15 | ||
Its been common knowledge for donkeys years that dex 3 is a holden fluid for their autos and will kill a ford auto,why people are saying it will be fine dumfounds me..
Only ford box its meant for is the 5 or 6 speed manual. How hard is it to just use tq95 the oil made for the btr? |
4 users like this post: |
25-11-2017, 01:40 AM | #16 | ||
So I ended up going to the shop to ask why Dex III was used, given it's not the right fluid.
I got a sigh and a then a load of anecdotal evidence that it's fine for the gearbox, "we've put this in dozens of taxis every year for several years... It's fine for the AU gearbox..." etc. I asked for actual evidence that it's suitable for use in a BTR gearbox and was told he didn't need to provide any and that I was making a stupid request. I ended up leaving before the discussion degraded any further. So I've decided I'll avoid going to the place in future. It's a shame because prior to this they've always done good work. I know they work on a load of taxis, but in this instance I think they have make a mistake and seem to be happier to lose a long term customer than just take the fluid out and put the right stuff in. In the next week I'll drain and replace it myself.
25-11-2017, 07:33 AM | #17 | |||
regards Blue Last edited by aussiblue; 25-11-2017 at 07:50 AM. |
26-11-2017, 01:05 PM | #18 | ||
XR6T BA 2002
Penrite Full Syn is what i use
Some browsing material https://www.fordforums.com.au/showth...s+fluid+change https://fordforums.com.au/vbportal/v...articleid=1210 https://fordforums.com.au/showthread...c+transmission
XR6T 2002 BA
26-11-2017, 01:51 PM | #19 | ||
RIP...
I've been using the cheapass Burson multi DX3 for ages in my yoot, goes good and does heaps of heavy towing.
The oil he's supplied is most likely just fine.
. Oval Everywhere... |
26-11-2017, 03:24 PM | #20 | ||
For those saying Dexron is OK read https://www.tiperformance.com.au/Ref...Speed_Auto.pdf especially pages 31 and 47.
regards Blue |
26-11-2017, 03:59 PM | #21 | ||
And even in the FG factory workshop manual for the 4 speed BTR (used in the LPG vehicles) Ford warned that using anything other than TQ95 would result in a reduction in performance and durability.
regards Blue |
26-11-2017, 04:15 PM | #22 | ||
As an aside, it would be interesting to see what happens though if someone used TQ95 in a trans meant to have Dexron III.
regards Blue |
26-11-2017, 06:03 PM | #23 | |||
RIP...
I remember all too well how many BTR's were killed using the wrong oil, back then. It's not much different to when Ford released the ZF, nothing else could be used except the Lifeboat or whatever it's called, yet now there's several that can be used. Things change. Todays pooftamatique fluids have advanced somewhat since then. BTW, I don't think anyone has said all dexron fluids are ok to use, however there are some that can.
. Oval Everywhere... Last edited by Sox; 26-11-2017 at 06:32 PM. |
26-11-2017, 06:40 PM | #24 | ||
Cabover nut
Do not know anything about Ford autos but would this apply to earlier XF 3 speed autos ?
26-11-2017, 07:44 PM | #25 | |||
This whole conversation reminds me of the ZF 6speed oil. Most say you must use the ridiculously priced ZF oil. But there are many other successful alternatives . Here's one for you. Some years ago where I work had Allison transmissions in small mini buses . The original oil was Dexron 3 . There was issues . Now this particular Allison was nothing more than an overgrown T400. The fix from Allison was ... Fill with a 15/40 diesel engine oil. I'm like "No Way" but issues with overheated oil went away. The heavier oil shifted just the same |
26-11-2017, 08:14 PM | #26 | ||
Perth WA
It's based on the friction modifiers! One is grippy and one is slippy..
So if you switch them over, you will get a much firmer shift in the Ford and a softer shift in the Holden.
2008 FG F6 310 - Auto 384KW/850Nm(RW) Monsta Torque WA : Prestige Exhaust : AutoFX Paint Protection : Gino's Panel & Paint : AC Automatics : 2016 Jaguar XE Black Pack R-Sport |
