06-11-2017, 10:00 AM | #1 | ||
With the system now where the clutch has to be depressed to start the engine,is it possible to roll start a vehicle now.Does the clutch in mode only isolate the starter motor or does it immobilise the whole ign system.If it immobilises the whole system then, I guess when the clutch is engaged without the engine running then, there will be no ignition power supply so therefore no start!!
06-11-2017, 10:58 AM | #2 | ||
It would be a real PITA to restart the engine every time you changed gear.
06-11-2017, 12:30 PM | #3 | ||
06-11-2017, 12:42 PM | #4 | ||
Marshall!!!!
06-11-2017, 12:49 PM | #5 | ||
Are you suggesting you can't start these things in neutral or in gear with the clutch out?
That would suck, how could you drive the car if it had a broken clutch cable? Is "roll start" Tasmanian for "clutch start" in Australian or does roll start have a different meaning down there? My first post was a bit tongue in cheek because I thought you were joking but now I'm not so sure, these modern cars keep catching me out. |
06-11-2017, 01:02 PM | #6 | ||
(Avoiding semantics) I have a car that will start by letting out the clutch as it is rolling.
However, when starting normally, the car will not start unless the clutch is fully depressed. |
06-11-2017, 02:28 PM | #7 | |||
06-11-2017, 02:41 PM | #8 | |||
06-11-2017, 02:54 PM | #9 | ||
Some euros have had it for decades, we had a Volvo s60 circa 2000 that had it.
Much newer s80 has it. I don't think the zf has this feature though, its a mechanical lockout and you can feel it in both the pedal and gear lever.
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
06-11-2017, 03:04 PM | #10 | ||
06-11-2017, 03:39 PM | #11 | |||
Anyway, the "lockout" on them pretty much only affects the signal from the key to the starter - it simply won't crank. Everything else works as normal - hell you could even hot-wiire the starter trigger and it would start fine. So clutch-starting is not an issue in them - it doesn't cut ignition/fuel/ecu power. |
06-11-2017, 04:17 PM | #12 | ||
Just checked my Ranger for this. It's an electrical interlock which means that you have to have brake pedal depressed AS WELL AS ignition on, to be able to take it out of park. I tried to shift out of park by depressing brake pedal with ignition off and no go. I also tried to leave in neutral but key is locked in the ignition until it's in park. Tried these also with handbrake on and off - no difference. Does this mean that if you have a dead battery, then you are stuck in park which means towing or even a tilt tray is no go?
06-11-2017, 04:25 PM | #13 | |||
06-11-2017, 04:26 PM | #14 | ||
VFII SS UTE
i have often wondered myself, as my car is the same.
can i clutch or call Marshall? autho the wife Hyundai is the same that can be clutched my one is push button not key and has electric park brake..
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
06-11-2017, 05:54 PM | #15 | ||
