Old 07-10-2017, 10:11 PM   #1
Neme
Needav8
Neme's Avatar
Default AU3 XR8 calipers, difference from BF/FG etc?
Been looking at the usual brake upgrades etc.... One option I've seen by chance (for FG owners) is buying new spacers for FG front calipers to let them fit the 322mm rotors....
However, looking at what pics I can find, and my own brakes, I'm wondering what is the actual difference between the calipers?
I ask because when you look at the AU3's factory brakes, the calipers in the front are pretty bloody big, and they look almost identical (casting etc) to the FG brakes I've seen for sale. It's only the rotor that is tiny....
If you can buy a spacer to move the FG caliper out to suit a bigger rotor, what are the odds they work on the AU3 calipers?
Here's mine, crazy small rotor for a big caliper:
These FG calipers that would need a spacer looking exactly the same housing etc?
http://www.ebay.com.au/itm/Ford-BA-B...r/142524134084
Back in the game with an '02 AUIII manual XR8
Neme is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2017, 09:36 AM   #2
te5000
te5000's Avatar
Default Re: AU3 XR8 calipers, difference from BF/FG etc?
When you put the au caliper beside even BA calipers they are physically smaller . The AU3 on top and BA below
Sent from my SM-G930F using Tapatalk
te5000 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2017, 09:52 AM   #3
superroo
You can't stop the signal
superroo's Avatar
The problem is disc size.
AU's run a 289 diameter disc.
Bf/FG have 298.
The adaptor on an AU caliper won't take you to a 322 disc.
Old 08-10-2017, 09:25 PM   #4
gregaust
What about the AU vs BA mounting points ? Been trying to find if they are similar on the caliper itself ??
Old 08-10-2017, 11:06 PM   #5
superroo
superroo's Avatar
To the upright?
Definately yes. Both my AU's have have BA calipers.
To the slide pins on the caliper?
Not sure.
Old 08-10-2017, 11:14 PM   #6
te5000
te5000's Avatar
You can bolt on ba /f calipers direct to AU3 stubs using ba/f discs. Mounting points are same. AU1 are same mount sizes but different stub axle design.. i run BF 6pot brembos on AU3 stubs/uprights. Another of our cars has the standard ba/f calipers mounted on AU stub / uprights.
If you wish for a dirt cheap upgrade ba calipers and discs drop straight onto AU3
Old 09-10-2017, 12:18 AM   #7
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Hi te5000, just wondering if you were referring to a AU1 & if so, can you please share any info on how this was achieved? Any info greatly appreciated!
cheers, Maka
Old 09-10-2017, 12:29 AM   #8
mcfly94
mcfly94's Avatar
cheers, Maka
Probably not, au1 is nothing like au2/3 ba/bf.
Au 2/3 brakes wont go on au1 let alone ba/bf.
Fg goes on au2/3 ba/bf i think by switching left and right calipers.
Best thing for au1 is au 2/3 front end conversion, then brake upgrade.
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2017, 09:10 AM   #9
te5000
te5000's Avatar
You are right mcfly. AU1 are different. The first pic shows AU 3. Then there is ba upright with brembo. Then AU2 with AUpremo brakes (factory fitted). Last pic shows au1 vs au3. 1 on left 3 on right. Note that there is a difference between caliper mount points. Fitting big brakes to au1(like brembo) can go on but they hit tie rods, you have to change to later uprights as well as swaybars.
Last edited by Raptor; 09-10-2017 at 10:25 AM. Reason: Bloody tapatalk, grrr. Put a space btw the images.
Old 09-10-2017, 09:14 AM   #10
te5000
te5000's Avatar
cheers, Maka
No AU1 big brake upgrade is a lot of work. Change upright and swaybar that would include drilling the chassis rail and installing nutserts in the rail to mount the sway bar brackets
Old 09-10-2017, 09:41 AM   #11
Maka
Maka's Avatar
Hi te5000, thanks for your reply mate. Yeah i know about what fits what & how, i just wanted you to confirm which model in the quote as it was a tiny bit ambiguous & thought you may be referring to AU1.
As a AU1 owner any tips or new tricks to have upgrade brakes are always welcome & handy, I'll be doing the conversion soon. Cant wait!
cheers, Maka
Old 09-10-2017, 09:44 AM   #12
te5000
te5000's Avatar
cheers, Maka
Typing with a phone sux for me so answers/comments tend to be a little short and a little disjointed. By the way the other pic i put up in this thread shows a t1 te50 with 6pot brembos. It can be done
Old 10-10-2017, 01:30 PM   #13
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
And just to answer that question here is a pic of the AU 2/3 caliper compared to the 322mm disc caliper out of BF Turbo.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2017, 02:33 PM   #14
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
See this => Falcon Brake Dimensions XK-FG (it's in the Tech Resources area)
Slight variation between the models on both master cylinder bore and front caliper piston diameter (x2).
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2017, 06:51 PM   #15
Peuty
Afterburner + skids =
Peuty's Avatar
Is there any real advantage to upgrading the rear calipers and discs on my AU2 XR8 to, say, BF items?
I get that they are bigger, but realistically, will I notice a difference? I need new discs and pads on the rear and am thinking about doing the upgrade while I am there.
Oo\===/oO
Old 16-10-2017, 05:27 PM   #16
Peuty
Peuty's Avatar
Any ideas guys?
Oo\===/oO
Old 16-10-2017, 08:22 PM   #17
Sox
RIP...
Sox's Avatar
There's very little improvement in performance, it's mainly a looks thing - slightly bigger rotor to fill the wheels.
Having said that, it's a very straightforward mod, and quite cheap.
Oval Everywhere...
Old 17-10-2017, 01:33 PM   #18
Peuty
Peuty's Avatar
Thanks Sox!
Oo\===/oO
Old 17-10-2017, 05:52 PM   #19
Perana
Perana's Avatar
I've upgraded my BF N/A to Turbo brakes all round (Did the fronts a few years ago and the rears only a few months back) The fronts make a bigger difference, but I think the rears were also worthwhile to upgrade, and they are pretty cheap to obtain from a Territory.
Years ago we upgraded my Dad's AU2 XR to BF Turbo brakes front and rear and it made a massive difference so would highly recommend on an AU.
'09 SYII TTG | Mystic
'06 BF XR6 | Mercury Silver
Perana is offline   Reply With Quote Multi-Quote with this Post
