Old 25-08-2017, 08:54 AM   #1
Wretched
Render unto Caesar
Wretched's Avatar
Default Mercedes AMG Project One
"Mercedes-AMG has revealed the technology behind its forthcoming Project One hypercar, which is due to be unveiled at the Frankfurt show in September. And the hardware lives up to the hype: The ultimate AMG will have a fiendishly complex powertrain borrowed from the all-conquering Mercedes grand prix racers, with additional electric motors driving the front wheels to help deliver a total system output north of 1,000 hp.
The heart of the car is a 1.6-liter turbocharged V-6 based on the engine that powered Lewis Hamilton to the 2015 World Driver’s Championship. The heads are the same, as is the block, but the pistons and crankshaft have been changed to lower the compression ratio in order to get the engine to meet emissions regulations around the world. And although the original race V-6 would rev to a dizzying 13,500 rpm, the Project One’s version is limited to 11,000 rpm. Idle speed has also been brought down to 1,000–1,200 rpm instead of the race car’s 3,800–4,000 rpm."
http://www.motortrend.com/news/revea...ne-powertrain/
Nice, but I am more interested in the upcoming McLaren BP23
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson
Wretched is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2017, 09:30 AM   #2
Polyal
The 'Stihl' Man
Polyal's Avatar
Default Re: Mercedes AMG Project One
Its not that prevalent these days that race tech filters down, that fact alone with this makes it cool.
  • 1973 ZF Ford Fairlane
Old 25-08-2017, 01:09 PM   #3
Vesper Martini
Vesper Martini's Avatar
Electric FWD & 1.6T for RWD cool stuff
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2017, 01:11 PM   #4
Sioso
irregular member
Sioso's Avatar
I think it looks great as it is, just add a cage, seat, steering wheel and pedals.
Sioso is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2017, 01:32 PM   #5
whitelion65
whitelion65's Avatar
Interesting to see the two different geometries of the push-rod suspension.
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2017, 01:41 PM   #6
eb2fairmont
Wonder if one of the first buyers of the car is Ferrari or Renault
Cos you know ..
eb2fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2017, 01:54 PM   #7
XW 393
"WHEEZER" POWERED
XW 393's Avatar
limited to 11,000 rpm!
FG MK2 XR6 DAILY - BLOWN VE SSV Z SERIES TAILY
XW 393 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2017, 03:11 PM   #8
Bossxr8
Peter Car
Bossxr8's Avatar
If the race cars idle at 4000 rpm then I wonder how the engine would perform down at 1200 rpm, and with the limiter being at 11,000 rpm, how it performs across such a massive rev range, and with a turbo too. Would the turbo be variable geometry I wonder, cause it would be crazy laggy if it wasn't. Or do the electric motors fill the power band in. I guess wait until the first road tests happen to find out, but it is pretty fascinated how this will work as a road car.
Old 25-08-2017, 04:56 PM   #9
XW 393
"WHEEZER" POWERED
XW 393's Avatar
My guess is the electric motors bridge that gap, the 161HP motors for each front wheel will help that out.
Old 26-08-2017, 08:28 PM   #10
malazn mafia
Boss 335
malazn mafia's Avatar
The best idea would be Mercedes releasing the vehicle in that format with an adjustable wheelbase and the end consumer bolts whatever top hat he wants on top of it. Imagine the possibilities .
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2017, 01:46 PM   #11
Express
Bathed In A Yellow Glow
Express's Avatar
This is what the rest of the article says in the link Wretched has suppied.
This main power unit is bolted to a brand-new eight-speed automatic transmission, which drives the rear wheels. AMG engineers say they decided against a dual-clutch transmission because it would have been too heavy and would have had trouble keeping up with the little V-6’s ultra-high rev limit.
AMG hasn’t confirmed numbers, but the internal combustion engine develops at least 700 hp with the help of a massive single turbocharger and two electric motors. The unusual turbocharger is identical in layout to that used in the Mercedes F1 car. The exhaust turbine is located at the rear of the block and connected to the compressor, which is located at the front of the block by a shaft that runs through the vee of the engine.
A 107-hp electric motor mounted concentrically on the shaft (called the MGU-H, for motor generator unit-heat) is used to keep the turbo spinning at all times and to harvest excess energy generated by the exhaust and feed it into the battery pack. Mercedes-AMG development engineer Jan Feustel says the system means the engine has the response of a naturally aspirated V-8 despite the size of the turbocharger. Not all that 107 hp is used to spin the turbo—the motor’s power rating is also a measure of the amount of energy it is able to recover. “It could be smaller if it was to just to rev the turbo,” says Mercedes-AMG boss Tobias Moers.
The second electric motor, mounted low on the engine and called the MGU-K (motor generator unit-kinetic), develops 161 hp and is connected directly to the crankshaft, where it performs the same task as in the F1 racers, delivering a power boost when needed. In an F1 Mercedes that power is only available for a short period. In the Mercedes-AMG Project One, however, extra power will be available for longer and over a wider range of operating parameters.
Key to that capability is an 800-volt battery pack with four times the capacity as the one in the Formula 1 car. Capacity aside, the battery pack is otherwise identical to that used on the track, right down to chemistry, cooling, the way the cells are arranged, and the connectors. “You don’t want to know what it costs,” Moers says.
The extra battery capacity is also used to power the 161-hp motors connected to each of the front wheels. Like the Acura NSX, the Project One will use the motors for traction and performance and to actively vary the torque sent to each front wheel to enhance agility through corners. The AMG system looks significantly simpler than Honda’s, however. The motors are internally the same as the MGU-K, and like the V-6 engine itself, they are remarkably compact. Project One’s whole powertrain reportedly weighs 926 pounds, and 220 pounds of that is the battery.
With 322 hp of electric power at the front wheels, Project One will also be able to be driven with the V-6 internal combustion engine shut down. Pure EV operating range is not great—about 15 miles—but the Project One is not designed to be a daily commuter. However, it will be a daily driver, Moers says. Unlike with the Bugatti Chiron, there’ll be no special key required for owners to access the car’s full performance.
In addition to the powertrain, AMG revealed Project One will feature a sophisticated race car–style, height-adjustable pushrod suspension front and rear, giant carbon-ceramic brakes, and forged center-lock alloy wheels, 19 inches up front and 20 inches at the rear. The Pilot Sport Cup 2 tires—285/35ZR19 front and 335/30ZR20 rear—have been specially developed by Michelin to cope with the massive downforce the car will be capable of developing.
Project One will lower itself closer to the tarmac in Track mode—just like the new Ford GT—and although Moers won’t elaborate, he hints the car’s aerodynamics will be just as bleeding edge as the powertrain. “It’s not sensible to have such a sophisticated powertrain without sophisticated aerodynamics,” he says .
Bringing genuine F1 powertrain technology to the street has been a challenge. That highly strung internal combustion engine has had to be made to meet all global emissions standards, and the electric drive systems, a vital element of Project One’s performance capability, added weight. But the biggest challenge? Noise, vibration, and harshness. As in a Formula 1 racer, the Project One’s engine is a structural element of the chassis, bolted at the front end to the car’s carbon-fiber tub and at the rear to the transmission (to which the rear suspension is attached). “F1 guys don’t care about NVH in an engine,” Moers says, “and a V-6 is … not the best idea regarding NVH.”
Project One is right at the very limits of what is technically possible for a road-going automobile, so much so the powertrain has been lifed to just 30,000 miles before it requires major—and expensive—refurbishment. That’s not an issue for customers in this rarified market segment, Moers says. “The only thing people ask us,” he says, “is if they need a Formula 1 team or special support to run the car. No. You just push the start button, and you go.”
AMG plans to build 275 Project Ones, and all have been sold, with approximately 50 coming to the U.S. No official word on pricing, but it’s safe to say that if you have to ask, you can’t afford one.
It might be one of the edgiest, most technically advanced road cars ever built, but Project One is more than just a nice way to celebrate AMG’s 50th anniversary. It points to a future where AMG’s fastest, most potent cars will be plug-in hybrids. “It is going to be the future,” Moers says. “With hybrids you add performance and you increase efficiency. What’s wrong with that?”
The Mercedes-AMG Project One is therefore intended to redefine the notion of ultimate performance under the AMG brand. “If you have a strategy and you want to move into a new era, a new dimension of performance,” Moers says, “it’s good to have something that opens the door in a very authentic way. This car is it.”
Express is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2017, 02:48 PM   #12
Bossxr8
Peter Car
Bossxr8's Avatar
Epic stuff. So by the sound of it it has a massive turbo and uses an electric motor to power the turbo up at lower engine speeds.
Can't wait to see a drive review of this. Performance would be ballistic.
Old 12-09-2017, 10:19 AM   #13
Wretched
Render unto Caesar
Wretched's Avatar
In all its glory
http://www.motorauthority.com/news/1...s-over-1000-hp
Old 12-09-2017, 04:44 PM   #14
Chopped
as in chopped
Chopped's Avatar
I heard on the radio that 8 Australians have each placed $500,000 deposits for them. So 8 will be headed down under if all goes well. Would be nice to be able to afford a 5 million dollar car.
-> Reading this signature was pointless <-
Chopped is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2017, 06:02 PM   #15
futura
futura's Avatar
Wow! For the lucky 50 buyers. Hope they can drive, as this car would be more than a handful to drive.
GTF Smoke with Black stripes.
futura is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2017, 06:30 PM   #16
b0son
The only problem is that every time it needs to be repaired, you get a 5-place penalty at the traffic lights for every fault they find....
b0son is online now   Reply With Quote Multi-Quote with this Post
Old 12-09-2017, 06:30 PM   #17
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
The bodywork looks like a reimagined McaLaren F1 to me.
Which is fine as I still see that as the ultimate road car
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2017, 10:21 PM   #18
CoupeKing
https://www.youtube.com/watch?v=5yrCDArSCWA
CoupeKing is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2017, 07:38 AM   #19
cheap
Wirlankarra yanama
cheap's Avatar
Interestingly there is no 0-100km/hr time quoted, instead:
0-200km/hr in less that six seconds !
Where you can actually use this performance will be the biggest issue.
Owners had probably plan on having a really good chiropractor available to fix up their neck and spine, image the doctor asking if this was a work related injury, no I just floored my Mercedes One a couple of times too many.
cheap is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2017, 08:13 AM   #20
Nu66et
Most super/hypercars have moved away from quoting 0-100 though. These days when a Mustang can do sub 4 seconds 0-60mph its taken alot of the shock value away.
Nu66et is offline   Reply With Quote Multi-Quote with this Post
