Old 11-03-2017, 10:03 PM   #1
dj2015
Default Lead Replacement Additives
What lead replacement additives are people using nowadays?
Interested what other V6 Capri owners are running but guess the question applies to any pre-1986 Ford owners.
dj2015 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2017, 12:36 PM   #2
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
Default Re: Lead Replacement Additives
I used Morey's Power Lube before I reconditioned the heads on my LPG fuelled cars with stainless valves and hardened (stellite) seats.
Power lube is a bit of a misnomer, it's an upper cylinder head lubricant.
You can buy a kit with a bottle/bracket and a rubber line that you plumb into under the butterflies of the carby, also comes with a thin brass barb and thread tap if you don't have a readily available vacuum source. Flow is regulated at the bottle via a tapered needle similar to an idle mixture screw. I went for the kit for the sake of convenience.
http://www.moreyoil.co.nz/moreys-pow...cating-system/
You don't have to buy the kit, you can simply add it to your fuel tank after you fill up - not sure on the ratio/litre, it's on the bottle.
Available from most of the big chain auto stores.
Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2017, 11:39 PM   #3
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Never used the stuff. Seventeen years since we lost leaded fuel and not one problem so far...
Escort RS2000 Restored factory a/c and alloys.
TD Cortina Unrestored 35 000km 6cyl manual.
Mk1 GT Cortina Project.
FG XR50 Daily.
Rallye Sport is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2017, 06:02 PM   #4
JessieXT
JessieXT's Avatar
I use Premium 98 in a 1973 Cortina. No issues.
JessieXT is offline   Reply With Quote Multi-Quote with this Post
