Old 10-01-2017, 06:44 PM   #1
T3rminator
T3rminator's Avatar
Default What grease for o2 sensor threads
Car has been running rough, and recently threw a P0171 code, so I decided to clean the O2 sensors. Currently have the sensors soaked in petrol.
When I put them back in, do I need to use grease / anti seize on the threads? If so, can I use any old grease or does it have to be a specific kind?
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2017, 06:48 PM   #2
superroo
You can't stop the signal
superroo's Avatar
Default Re: What grease for o2 sensor threads
Anti-seize.
New sensors generally come with this already on the threads. Helps removing them after heat cycling
Old 10-01-2017, 06:52 PM   #3
Fgute
My new 02 sensors came with grease but I can't help on what type it was.
Fgute is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2017, 08:44 PM   #4
LukaPuka
Gen Y Falcon nut
LukaPuka's Avatar
copper grease is usually the go
BA XR8, Boss 315, T56, Herrod Cams, BPR CAI, X-Force head to tail,
LukaPuka is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2017, 09:53 PM   #5
EBSXR6
EBSXR6's Avatar
Anti seize or copper grease. Super Cheap has anti seize for under $10 a tube.
EBSXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2017, 10:09 PM   #6
T3rminator
T3rminator's Avatar
Thanks. I'll have to pick some up tomorrow and re-apply it.
Damn...the car idles perfectly now, and the way it accelerates is way smoother.
Not sure if it is due to the O2 sensor clean, or whether because the temp is cooler and the tune is adjusting. The last week, which has been hot and humid in Melb, it was spluttering and coughing at idle.
Have also cleared the DTC so will see if P0171 comes back.
