13-06-2016, 04:27 PM | #1 | ||
I've been quoted $380NZD for replacing both rear bump stops, as well as $420-480NZD for replacing the rear discs and rear brake pads. The handbrakes need re-balancing and are included in the quote.
Also, I'm getting a transmission cooler installed (No Service needed apparently as the oil is in good condition) for $280. Do these sound like reasonable quotes to you guys? Any comments?
Project/Fun Car - BA MkII Fairlane Ghia
Daily Driver - Volvo V50 2.4 "If in doubt, flat out" - Colin McRae "Horsepower is how fast you hit the wall. Torque is how far you take the wall with you" "Cheap, fast and reliable. Pick Two" |
13-06-2016, 04:33 PM | #2 | ||
All in all the car had a thorough inspection and these were the only issues found. I have to say I'm extremely impressed with the car. 420,000 and still going strong. Kudos to you Ford, you've built a tank of a car.
13-06-2016, 05:19 PM | #3 | ||
Lucifer's Angel
If you have any space, or a friend with a garage and ramps, replace the bump stops yourself. I think I paid $27 for aftermarket ones from Pedders. It takes about 10 minutes.
Otherwise, I'd be shopping around. That seems steep. If that isn't an option, then at the very least I'd do some research and supply the parts to the workshop you go with.
SINISTER BA XR6 Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford... It's being beaten by a girl driving a Ford |
13-06-2016, 05:26 PM | #4 | |||
13-06-2016, 09:37 PM | #6 | ||
Lucifer's Angel
I literally just backed my car on ramps to be able to get under it, pulled the old ones off by hand (they were stuffed), and with a little rubber lube, and not that much elbow grease, popped the new ones on. Simples.
Unless you're looking at specific pads and discs for an upgrade, they can all be sourced quite cheaply as well.
13-06-2016, 09:53 PM | #7 | ||
Same ****-Different Day
For a $1000-1100 you could fly me over from OZ, buy a cheap jack and socket set, I could do those little jobs then you could take me skiing
Bax. Current Vehicles RA Wildtrak V6, UA2 Everest Trend 2.0lt |
8 users like this post: |
13-06-2016, 10:07 PM | #8 | |||
The way I see it, the bump stop quote was definitely a rip off, considering these are quotes from AA Service (They do the best inspections), I'm not surprised. I'm looking at taking it to an independent that I've used in the past for machining the front discs, and getting both the rear discs and the bump stops done at the same time. Assuming he's doing the discs and having the car up on jacks, I don't think the bump stop would require any extra labour charges. I checked and I could pick up some replacement bump stops for $55, so any quote higher than $80 for doing the bump stops I'll be immediately turning away, especially when he's already got the car up on the hoists when replacing the discs. Oh and also, I believe the AA quote was a general baseline quote that they have for a bump stop replacement job. I understand most cars have the bump stops within the coil and require a wee bit of work to get at. In which case the $380 quote makes some sense. EDIT : My bad. Turns out a pair of rear bump stops is going to set me back $98. Guess I'll have to settle for any quote sub $130 for the job them.
Daily Driver - Volvo V50 2.4 "If in doubt, flat out" - Colin McRae "Horsepower is how fast you hit the wall. Torque is how far you take the wall with you" "Cheap, fast and reliable. Pick Two" Last edited by Qwerty321; 13-06-2016 at 10:19 PM. |
14-06-2016, 01:10 PM | #9 | ||
Stock Boss
surely you've got the standard jack for the car?
I put some superpro ones in mine, didn't need any grease or anything to get them one, little bit of wiggling back and forth to get the stock ones off and then same to get the new ones on, job done.
03 BA XR8 Blueprint | Manual | Leather | Premium sound | Sunroof | Shockworks coilovers | TrueTrac + 3.73 Diff Gears
14-06-2016, 01:30 PM | #10 | ||
EDIT : Ignore this post. I did a stupid
Daily Driver - Volvo V50 2.4 "If in doubt, flat out" - Colin McRae "Horsepower is how fast you hit the wall. Torque is how far you take the wall with you" "Cheap, fast and reliable. Pick Two" Last edited by Qwerty321; 14-06-2016 at 01:47 PM. |
14-06-2016, 01:38 PM | #11 | |||
. Invest in jack stands and a proper 2000kg jack that you can then use for years to come. |
3 users like this post: |
14-06-2016, 01:46 PM | #12 | |||
I guess it's time I finally bit the bullet and bought some jack stands and a proper 2000KG jack. Would your recommend going with Jacks and jack stands, or going with ramps?
14-06-2016, 01:54 PM | #13 | ||
Total tools have a 2000kg low profile jack for around $170 that would fit under the bumpers or side skirts. Normal trolley jacks can be a problem to fit underneath the modern cars.
They would also have 2000kg safety jack stands. Get the type which have four feet rather than the ones with a metal base and square section tubing welded in vertically. |
14-06-2016, 02:12 PM | #14 | ||
Club Moderator
In regards to the use of the trolley jack, does anyone have a diagram or pictures, on where exactly are the recommended locations for the jack, and the stands on a Ford Falcon.
15-06-2016, 05:58 PM | #15 | |||
http://www.fordforums.com.au/showthr...ht=jacking+car |
15-06-2016, 07:01 PM | #16 | ||
Seems tome to be a lot of cash for a job that should entail about $120 discs and pads,$40 bump stops and about 2 hrs labour.Better you take 2 days off work and take the time to do the job yourself.
15-06-2016, 07:16 PM | #17 | ||
In terms of the bump stops, the price you were quoted is insane. They are about $30-40. To replace you dont even need stands or jacks etc. I just slid under the car and wriggled the old ones off and pressed in the new ones (from pedders) in. And my car is lowered too. Suggest you have a go as it was easy as, and will save you a fair amount of $.
FGX XR8, auto Vixen BA XR8, auto. Lightning Strike FG XR6, manual. |
15-06-2016, 08:40 PM | #18 | |||
And you got to factor in the NZ factor mate. The parts here are always going to be costlier than over the ditch. All the spares we get here are likely imported over from aus, so you've got to factor in that cost, as well as how our dollar is typically significantly weaker than yours. The quote I got for the parts is straight from Supercheap Auto. $97.77 including GST for a pair, and Repco were fairly similar in their pricing too.
16-06-2016, 01:02 AM | #19 | ||
So they inspected the car, diagnosed it as needing bump stops replaced, but were unable to be sure of where they are located and how much labour was involved?
Mate. They tried to rip you off. Pure and simple. I wouldn't make or accept excuses for them. Glad you're getting it sorted without getting it too hard in the butt. You were right to check on here first, that's what the forum is for |
16-06-2016, 08:06 AM | #20 | ||
Just wondered how they new the oil was OK?
Did they test it? Or did they guess? If they are using the old sniff and look method then if it's knackered enough to tell that way (which is extremely unreliable) the tranny usually suffers before it looks bad enough to tell? Just wondering? Cheers Steve
MainLube - Extreme Lubricants For Overdriven Machinery Mainlube 175 Synthetic Race Oil SAE 10w60 (engine) Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox) Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w140 (diff) www.Mainlube.com.au |
16-06-2016, 10:15 AM | #21 | ||
BA/F6 BF/F6 SSV/R TTG
They have X-ray glasses they got from the backpage of the comic book
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
16-06-2016, 01:59 PM | #22 | ||
On the note of the oil, I'm fairly sure they have an oil testing machine. I believe its a proper machine for engine oil and some spot/swab disc style tests for ATF. Whether or not they used it is of course another story, but I'll give them the benefit of the doubt.
On the note of the quote, the inspector and quoter are different people. They have a team of about 7 people working in the workshop, one of them did the inspection and then wrote down everything that was wrong on the inspection sheet. The quote comes from the receptionist person. She basically fills everything from the report into the computer and selects everything that is wrong, and this then gets printed out with a quote on it which is whatever is listed as estimate for that job on the computer. Obviously its not a great system. I know AA do have a policy of genuine parts for everything so that could also drive up the price. I was given a copy of the inspection sheet and the print out quote. Inspection sheet which is hand written by the inspector has no quotes on it. As I said, I never planned on getting the job done with AA. I just went there for the inspection as they do inspections best. Have rolling roads, suspension test machines and what not.
16-06-2016, 02:14 PM | #23 | ||
Them trying to pull a fast one is a possibility. All I'm doing is playing the devils advocate here to get both sides of the story. Either way, this makes no difference to the actual situation and really isn't worth us getting riled up about.
16-06-2016, 07:37 PM | #24 | ||
Don't think anyone is getting riled up. You asked if quotes were reasonable and received some responses. All good.
