25-03-2016, 04:54 PM | #1 | ||
Has anyone installed a dashcam in the LZ Focus? I am trying to find out if the engine stop/start system interferes with the dashcam if the camera is installed into the cigarette lighter. There seem to be situations whereby the dashcam is turned off in vehicles with stop/start systems.
25-03-2016, 05:45 PM | #2 | ||
Marko
In my LW it turned off after the lighter turned off, a few minutes? And turned on as soon as unlocked as lighter powered up.
I connected mine to the fuse box. A bit fiddly to do but I had a power pack with it so it stayed on for a while and was in standby constantly for parking situations
May the FORD be with you! |
25-03-2016, 06:03 PM | #3 | |||
I'm not interested in recording when parked, so it turns on when the doors are unlocked and it turns off 20-30 mins after the ignition turned off and doors locked. (Cigarette lighter stays powered on for that 20mins after car turned off) Easy install, I run the cable along the roof, A-pillar trim, door rubber down to the floor then under the passenger seat to centre console socket. All done within 10 minutes, with no wires visible, all inside the trim.
2009 Ford Fiesta econetic - silver (sold 2012) 2012 Mazda6 Touring Wagon - silver (sold 2015) 2015 Ford Focus LZ Titanium - Magnetic (sold 2019) 2018 Ford Focus SA Titanium - white (current) |
31-03-2016, 11:56 PM | #4 | |||
I'll be installing mine this weekend. Just one question.. How did you get the cable behind the A-pillar trim? Is it just the rubber door seal holding it on or did you pop the trim off somehow? Thanks. Norm |
01-04-2016, 10:39 AM | #5 | ||
Marko
In both our cars I pulled the rubber off and poked it behind the trim and put rubber back
01-04-2016, 01:41 PM | #6 | |||
The roof trim is the worst, as it doesn't have a tight front edge, so have to allow a little extra cable to avoid it coming out. Had the complimentary 'service' today and they unplug the dashcam to avoid me seeing what they get up to. 😜 Mazda didn't mind me leaving it on, maybe they had nothing to hide.
01-04-2016, 08:39 PM | #7 | ||
02-04-2016, 12:42 PM | #8 | ||
Okay, scratch my below concerns about the A pillar trim problems. After removing the door seal and pulling back the top of the A pillar trim, I was able to pass the wire behind the airbag stuff in there so all good.
Still have to permanently wire the thing in (just plugged into the accessory port at the moment). The only problem was sound distortions due to vibrations. Nothing a couple of strips of draught tape stuck on either side of the windscreen mount didn't solve. Pulling the cam on/off is a bit harder but I don't really intend on removing that often. Hopefully wont melt in the heat leaving it in place Now just to find the right fuse that won't have permanent power to tap into. Pretty happy so far |
02-04-2016, 12:46 PM | #9 | ||
Marko
Does your car have fog lights? Mine didn't switch on unless key was on/dash lights illuminated. Or aircon would also be suitable
02-04-2016, 01:33 PM | #10 | ||
Marko
Just out of curiosity what model is it
02-04-2016, 01:38 PM | #11 | ||
Hey Marko,
I have an LZ Trend so it has fog lamps. I'll go through and find a fuse somewhere. I don't mind if the power stays on for 10 minutes after locking up the car like the accessory port does, just don't want it to be always on. May run down to Jaycar today and grab the bits I need and start playing around with it |
02-04-2016, 01:42 PM | #12 | ||
Marko
Another option is tap into the aux plug in behind so the plug is still free to use
03-04-2016, 07:19 PM | #13 | ||
Mission accomplished, put the attached together for about $20. The front fog lamps (fuse 75) is always live so couldn't use that in case I forgot to turn on/off the cam whenever I went somewhere. Ended up finding fuse 85 (listed in the manual as Air conditioning, Moonroof, Heated seat switches, Passenger airbag deactivation switch) is only live when the ignition is on. Happy days
Now just need the dash mat to cut down on screen reflections. Last edited by NormM67; 03-04-2016 at 07:30 PM. |
05-05-2016, 12:10 PM | #14 | ||
I've found since installing the dashcam the "hold OK to reset" doesn't work. The trip computer still works but won't reset.
Anybody experienced this? Will most likely take it back to the place that installed it.
Currently no V8 in the garage! |
05-05-2016, 01:27 PM | #15 | ||
I've had no problems with mine such as you describe although I installed mine myself. Actually installed it twice now as I upgraded mine to a better cam last week.
06-05-2016, 09:21 AM | #16 | ||
Marko
That'll be a different issue. There's nothing on the fuse box that you could have disrupted that would cause that.
Sent from the Bat-phone
