Old 24-08-2007, 04:42 PM   #1
leadsparkie
Default Removing overspray
Just wondering if anyone can help. I've just noticed that my landau is covered in fine white paint overspray. It's not very noticeable but I discovered it when I was cleaning the vinyl roof. I'm guessing that it is oil based. I don't know if it is something that has happened since I've owned the car or whether it was there when I bought it.
Just want some advice on how to remove it, mainly from the roof, or if anyone knows a good car detailer in Melbourne. Thanks. Tony.
leadsparkie is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2007, 05:00 PM   #2
DOC
DOC's Avatar
Normally a clay bar would be fine to remove minor overspray, but you are refering to the the vynal on your roof which may need a different approach, each car needs to be looked at for its own problem and general advice may be wrong, my guess is a light rub with some vynal and trim cleaner on a cloth should sort it but always remember less is more, so dont scrub into and cause more damage / any damage.
My suggestion is drop over to the waxit forum and chat with dave ( throw a link ) and perhaps provide a pic and i am sure dave would be able to supply the right advice and product to fix the problem.
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2007, 10:12 PM   #3
ltd
Force Fed Fords
ltd's Avatar
Thinners. Vinyl is predominantly plastic and is often resilient to hydrocarbons, try a little inconspicuous patch and wipe it down with soapy water to get an emulsion and remove the thinners from the vinyl surface.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2007, 10:17 PM   #4
Dave_Waxit
www.waxit.com.au
Dave_Waxit's Avatar
Don't use thinners or Prepsol............ many years ago I had a ZG Fairlane which copped a ton of overspray when some guys were painting a fence.
After cleaning the paint off with prepsol, we tried a tiny spot on the vinyl and it reacted. As the paint was house paint in my case after a few washes most of was gone.
Do you know what kind of paint it was?
Dave.
Dave_Waxit is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2007, 08:39 AM   #5
leadsparkie
thanks for your advice. unfortunately I dont know what sought of paint it is. I dont even know when it happened or how long its been there.
