Old 27-08-2015, 07:55 PM   #1
The Big V
The Big V's Avatar
Default AU Fairmont Ghia electrical issue?
I have a 1999 model AU Fairmont Ghia.
When driving or in park with the ignition on the reds engine off.
When I apply the brake pedal the parking lights come on and also the stereo lights turn off and the power window switches light up.
Anyone had this problem or know what is causing it?
Thanks in Advance.
The Big V is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2015, 01:06 AM   #2
Fyrestorm
Spanner Thrower
Default Re: AU Fairmont Ghia electrical issue?
Sounds like the brake pedal switch is connecting to the parkers illumination. Had any work done to either lately?
1999 AU Futura Wagon (Nickname Betsie the Barge-***)
Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG.
Awaiting Wife Approval Mods:
TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things!
Fyrestorm is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2015, 09:00 AM   #3
The Big V
The Big V's Avatar
Only thing I've done recently was change the battery and a stop tail globe.
Old 28-08-2015, 09:18 AM   #4
T MAN
T MAN's Avatar
you have either put the wrong type of globe in the stop/tail light, or managed to put it in the wrong way, or the plastic globe holder is cracked or broken causing crossed connection..
T MAN is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2015, 09:24 AM   #5
The Big V
The Big V's Avatar
Ok will have a look.
Old 28-08-2015, 03:24 PM   #6
The Big V
The Big V's Avatar
Thanks TMAN your a legend.
I had the wrong bulb type in there.
Fixed all good now.
Thanks again.
Old 28-08-2015, 03:45 PM   #7
T MAN
T MAN's Avatar
no worries, glad you got it sorted..
