Hi,
Following my "noise in the clutch" post, you probably think my car is a music box, but still, there is yet another noise... So I brought the car to Ford for a regular service on wednesday. I bring it back on thursday because I started hearing a noise after i picked it up. From the inside, you can hear it commes from the passanger side, s I open the bonnet/hood and approaching my head to the space between the battery and the engine, I hear there is like an intermittent whistle. At first, they have no idea what it is, so the ask me to leave it with them. In the afternoon, before they close I call and ask if they figured it out. They tell me "its normal operation, we ocmpared to another WQ Fiesta"... Obvisouly, when I got thee, the other Fiesta wasn there so I couldn't compare myself. Their explanation is that there is avalve that opens and closes to release pesure... I am pretty sure I did not hear that sound before, and it bothers me a lot because I saw the car 4 times and test drove it 4 times before buying it last thursday and now, one week later, there is a something going on already... I recorded the sound. Its in the "Engine.doc" file (just rename it to Engine.mp3). From the begining, you hear the whistle, then at second 6, its stops and starts again. Then I moved so it makes a weird noise, but then from 10 to 13 you can hear it perfectly comming and going. Is this normal? Or should I bring it to another mechanic? Because I can't afford going to a mechanic for nothing... If your guess is "the steering pump", that's not it. That also makes a sound, but you can hear it comes from the steering side, not from far away, from the battery side ![]() The exact car model: Ford Fiesta Zetec Mk6, 1.6L, engine DuraTEC Thanks!! By the way, its absolutely not this noise: https://www.youtube.com/watch?v=jxPVnHQia1A Last edited by excalibur1491; 10-04-2015 at 10:04 PM. |
If it's not affecting the overall performance of the car mate then I wouldn't be overly concerned about it myself, electronic injection makes a lot of noise on engines too and along with emission control valves etc etc ..... they tend to make a variety of noises. In the meantime just drive it and see. If the Ford service dept. say it's normal operation and you're concerned about it ask them to put it writing for you, then if there is an issue you will have something to document that it was checked by them and passed as OK
![]() ![]() Last edited by Russ; 11-04-2015 at 09:37 AM. |
Over Thinker
Their explanation is that there is a valve that opens and closes to release pesure...
these newer cars ..really .. ![]() sorry only have an old version of windows ..cant open your word doc
My car goes Brumm Brumm Last edited by dirty hands; 11-04-2015 at 10:28 AM. |
#4 | |||
Russ, yes, I might go get them give me a paper that says that they thought all was good...
If you could take a look, that would be awesome ![]() Thanks! |
Hi again,
I went to another mechanic and he said it could be the "fuel pressure regulator". He will take a look on thursday to the car. Does that seem reasonable? I dont even know what that is myself! thanks! |
Over Thinker
I need more time to get my head around this engine design
if the engine uses shims on valves its something else it sure idles high back later the noise is at cam speed interesting its too noisy an engine...so how many km on it http://picosong.com/VWDJ/ Ford Fiesta Zetec Mk6, 1.6L, engine DuraTEC on youtube turn the crappy music down the valves system look like a cam shim design ah maybe timing chains cogs and guides worn out .. the tensioner is a spring type ... https://www.youtube.com/watch?v=l7MUL3vtZ5o
My car goes Brumm Brumm Last edited by dirty hands; 14-04-2015 at 12:13 PM. |
#8 | |||
Hi,
Thanks for your help! ![]() It only has 97000kms. Its not too noisy honestly, but I put the phone when I recorded really next to the engine with the hood opened so maybe that's why it sounds loud. The timing belt was changed not too long ago (at 90000km) and since Ford tried to very much rip me off, if there was something wrong with that, they would have said for sure. Also, the noise comes from the opposite side to the timing belt. It really sounds like air or some liquid is leaking from somewhere, but I can't see where or why.. It has to be something that they could have done wrong... Thanks again! Quote:
Over Thinker
fianally found this
this is a 2008 fiesta Zetec 1.6 petrlo engine idleing go to 7:00 when they lift the bonnet .... that is how it should sound https://www.youtube.com/watch?v=qu5hFyKfYIs Now I am confused all timing belts but not for a duratec motor only diesesls and zetecs http://www.fordpartsuk.com/shop/c/en...omponents_472/ found the timing belt http://www.fordpartsuk.com/shop/ford...2144_c_472.htm .the duratec engine by youtube ...claims it has timing chains ..Now I cant find the part listing
My car goes Brumm Brumm Last edited by dirty hands; 14-04-2015 at 03:39 PM. |
#10 | |||
Hi,
again, many thanks for your time, man! Looking at the video, I can tell its sounds pretty much the same, but ill check again tonight when I come back home from work. The sound I recorded, I really putt he phone next to the engine (like 5 cm away) so it sounds loud, but that way you can clearly hear the weird noise. Mine is a petrol engine, and I am 100% sure it has timing belt. My brother has the same car, and its a timing belt. And I know they changed it and the water pump before I bought it, I saw the invoice ![]() I still can't figure out what the problem is... The mechanic I saw yesterday said it could be the fuel pressure regulator, that might be full of **** and has to release pressure all the time.. I don't even know if that makes any sense, but at least this guy looked like he knew something, not like the guys at Ford.... will never go there again.. Quote:
Over Thinker
as long as it sounds the same as that 2008 demo
think everything under the hood should be ok keep us posted
My car goes Brumm Brumm |
#12 | ||
it does sound a bit noisy, but it is always hard to tell with a microphone, they pick up every single metalic noise on an engine.
Now you all scare me haha
The only problem I hear is that sort of "whistle/air-leak". I don't feel like the engine makes a very loud sound... maybe I should make a video. It honestly sounds the same as the Ford Fiesta auto that I saw after mine starting doing that whislte thing to compare. Maybe, also, I don't remember, but I put Unleaded 91 by mistake, I think I recorded the sound while it still had Unleaded91 in it, now I put unleaded 98 because the manual says at least 95. Thanks again guys! |
#14 | |||
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. |
#15 | ||
Thanks!
The guy at the station said "Just use unleaded 91" when I asked about E10. Honestly, my first car, right after I bought it, I didn't think too much. Wont make that mistake again! Anyway, I don't think that would explain the whistle. Hopefully the guy on thursday will be able to figure it out! thanks! |
#16 | |||
the old smart phone camera is pretty good for snapping a bunch of pictures in areas you cant get your head around to see, you can wack them on the pc and have a really good look for anything that looks wrong or out of place, vacuum hose off , leaks ,etc. i have no clue how much plumbing is on the fiesta, if theres stuff hard to see it might worth a look. it also be worth just getting a screwdriver or two and a couple of spanners and double check theres nothing loose, air intake hoses, manifold bolts,exhaust, etc,etc. |
#17 | ||
Don't understand the 91 hate.
Never put anything else into our WT, because my employer pays for it and he's a tight ****! (Nah, just kidding, he's pretty good) I don't have any noises or any noticeable loss of power. Though I have always thought it was underpowered after driving the Barina Sri for years. I don't think I've ever seen anything in the manual about 95 only. I stand to be corrected though. |
#18 | ||
Hi,
I just uploaded a video. At second 5 and next few seconds you can totally hear the hiss, otherwise, a the end, no way you can miss it. https://vid.me/CZUY I brought it to the mechanic today, he said he would tll me by 3pm. I didn't call, so I call him back and the secretary told me they were trying to clean something (he had no clue what) and they would call me tomorrow. I hope they didn't damage th car more than the guys at Ford... Can anyone identify that sound? If the mechanic doesnt find out but you do, Iĺl let you know your hypothesis! Thanks guys! |
#19 | |||
Our WP fiesta on the other hand, 91 made a massive difference. its rated at minimum of 95. On 91 it was horrid, noisy, rattly, down on grunt.
#20 | ||
Over Thinker
yes I hear the hiss you are not going bonkers also @45 as you near the battery --
no I cant say why or where yours https://vid.me/CZUY the 2008 no hiss just idle @7:00 https://www.youtube.com/watch?v=qu5hFyKfYIs
#21 | ||
Thanks dirty hands, at least now I know I'm not crazy.
I cant believe the guys at Ford told me its normal when they clearly damaged my car. If this mechanic is able to solve it, I'm going back to ford and I'm going to make them give me my money back, I'm going to make those bastards cry... they can do something wrong, mistakes happen, but not lie to me. |
#22 | ||
The hissing noise sounds like a vacuum leak to me.Check the induction manifold,PCV etc for leaks.
Live and Let Live |
#23 | ||
To me it sounds like a leak in a hose. Could that be?
Where can I find a simple (for me, who knows nothing about engine) drawing that explains where the PCV and induction manifold and what each hose is? OR if you could tell me where those 2 elements and the vacuum hose is, that would do. I suspect that hose as well. But can't tell the difference between hoses (why don't they use colors, like in electronics?) Thanks! |
#24 | ||
Tippy-tronic Free Zone
Look for small diameter vacuum hoses (e.g. 5-8mm small black rubber hoses) that might be disconnected.
Easy for any mechanic to be distracted when finishing off a job. Also, try an old mechanics trick. Use a cardboard tube or piece of poly pipe stuck in your ear with the other end close to the engine, and track the noise that way. This block out all the background noise that our noggins hear when we simply lean over something. This won't necessarily tell you 'what', but will help to pinpoint 'where'. Location of noises can be very deceiving. |
#25 | ||
Over Thinker
yes agreed
hold to the ear a funnel a pvc pipe a lenght of garden hose for bearings and metalic noises a long long screwdriver
#26 | ||||
I just came back from the mechanic, he doesn't know what it is. He said he checked the hoses and they are all ok, he believes something might be vibrating. Ill try your tube trick see if I find where that comes from. At least I'll go tomorrow to Ford to either get it fixed in front of me or get my money back... |
#27 | ||
These seems to be similar:
https://www.youtube.com/watch?v=hZtQhrdzQos Or this one, http://www.fordownersclub.com/forums...iss-in-engine/, but the guy never answered! (Dear future reader of my this topic, if I do find the issue, I will post it here so you can see it. Best, excalibur1491) This one though, says something useful: http://passionford.com/forum/ford-fo...e-hissing.html But I can't tell where that manifold is. I dont even know what the hell is that. |
#28 | ||
There can be a little blanking plug on the inlet manifold at the rear of engine on the firewall side, if it falls off it can cause a vacuum leak. Check with a torch and look for little pipe looking plastic piece, if you feel sucking air coming out, thats your problem.
Just a thought!! |
#29 | |||
I looked, and I couldn't see much. I tried o put my hand in different places, see if I could block something ant the noise stops, but my hand can't reach everywhere.... So I haven't been able to identify that. I went to Fod, they told me to come back on Tuesday, they'll take another look. I'm concerned they'll break something else, but I see no other option than leaving it with them. I can't pay another mechanic! |
#30 | ||
Over Thinker
looks like we are all back at school on this problem
ignore that this article is about bad idle on a zetec have no idea why or what . but it says in "rubber T peice "--there is a Pulse air system in the design this link will help you find your way around the engine bay with pictures http://www.gomog.com/allmorgan/ZetecIdleIssue.htm pulse air system explained - ford is near the bottom http://what-when-how.com/automobile/...em-automobile/ pulse time the 2nd http://www.smogtips.com/air.cfm how to remove pluse system from a Zetec ..good picture reference http://www.fiestaturbo.com/forums/fr...ec-e-vt101727/
My car goes Brumm Brumm Last edited by dirty hands; 18-04-2015 at 10:51 AM. |
