Have Boost, will use it..
When you start the car, the (!) hand brake light comes on.
But the light does not stay on if the hand brake is applied, i.e. you don't have a warning to say that the hand brake is on or that you haven't released it properly. No given that I have one of those right hand hand brakes, it is sometimes hard to tell if it is applied or not. Is there a simple thing to check? Is it just a wire or switch under the hand brake itself? |
Au Falcon = Mr Reliable
Yep, theres a switch there. Try wiggling the wire to the switch & see how you go mate. If that dont work check the connection to the switch, if no joy there replace the switch. Good luck!
cheer's, Maka
Had a look last night on the hand brake, and there isn't any switch or wiring there. Seems very strange. There is a connector of sorts with some wiring under the drivers seat, but as the seat is not electronic at all I don't know what that is for.
There doesn't seems to be any wiring going to or from the hand brake. Can anyone post a picture of this would be looking like? And it the hand brake on the right hand side of the driver. |
Hi Sam, we are talking about your utes handbrake hey? Sorry, I didn't realize that mate, thought sedan handbrake. Ive done a bit of googling for you but nothing has come up unfortunately, nothing in my workshop manual either. Maybe send a pm to foxtrot3, AMB or aussieblue they will probably know, or if worse come to worse take the ute to a sparky.
cheer's, Maka
#6 | |||
Thanks to aussieblue for his kind help -
http://fordforums.com.au/wsm/wire/aubx/Part%2024-5.html, it is the component marked C-49 in diagram G-2. I expect it is the can with the dark blue tab in the second pic in this thread http://www.fordforums.com.au/showthread.php?t=11250257 Also see the pic here - http://www.ebay.com.au/itm/FORD-FALC...item35e53ab76a Thanks for chiming in too Michael, very much appreciated! cheer's, Maka
Hi. In the drawing for low series cluster it shows as a separate globe for park brake (and a buzzer for ute) so maybe you have a blown globe and the lamp coming on when you crank the car over is the brake fail light. Wire colors for park light show as orange/dark green to the buzzer and red/blue to the lamp. Cheers MD
No, I don't have any wires... Will take another look and some pictures on the weekend.
