Old 11-12-2014, 07:58 PM   #1
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Seek button missing on steering wheel audio controls
Hi guys, i've just purchased a AU1 xr6 vct as a daily / project & one of the niggles is the seek button cover is missing on the steering wheel audio buttons - just wondering if i can i just replace the single cover or do i have to replace the three as a unit? Anyone know? All replies much appreciated (in advance), thanks!
cheers, Maka
Old 11-12-2014, 09:53 PM   #2
Dinoquad
Default Re: Seek button missing on steering wheel audio controls
By memory, I had to replace the switch, which meant taking the fuse out of the air bags, using the special torx screw to undo the steering boss , to undo the airbag to get to the switch, and the wiring. Replacing the switch was easier than mcuking around because the little do-hickey pivot things were broken on the switch, not the button.
Cost about $10 from the wreckers.
But I was hungover when I did it and you'll have to wait until I get hungover again to sort of remember better.
Dinoquad is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2014, 09:54 PM   #3
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I think it depends. I'll have a look out side (if it ever stops raining) I have few broken ones.
UK
Old 12-12-2014, 08:11 AM   #4
Maka
Maka's Avatar
Thank you guys for replying,
Dinoquad - don't take too long to be hung over again lol, thanks for the info!
Uncle Ken - thanks mate, i really appreciate you doing that for me - to me, that seek button cover has just popped off & i'm hoping another one can be popped back in but no biggie if cant.
cheers, Maka
Old 13-12-2014, 11:13 AM   #5
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
unfortunately there's no way to just "pop" another button into place. The plastic is too hard and won't flex to let you get it on without breaking the tabs off; which is why the first one came off, one of the tabs has broken off or the tab retainer has broken away. There's only 2 fixes that I've found along the way. The first is to just super glue the button cover to the actual button on the circuit board and the second is to just replace the button set. To do that properly you need to remove the wheel and then disassemble the wheel covers front and back to get the wiring out.(both sides are joined and have to be changed as one unit).
You can also do like I did the other week, and this can be done with the wheel still in place and just the airbag removed, and just cut the wires and remove the broken side and splice in the left side buttons from another broken set with damaged right side buttons. The only thing with that is you run the risk of the 2 sides being a slightly different shade of grey or black. It's like getting a panel off of another car the same colour and finding it has faded differently to yours and doesn't quite match.
MINE- AUII Forte
Old 13-12-2014, 11:53 AM   #6
Maka
Maka's Avatar
Thanks for that Bushbasher, great info! No superglueing so splicing maybe the go depends on what i can get. I know where there's some wrecked au's, i'll have look & try to colour match lol! If i cant get some the right shade i may well do the full job. I just had a another look & you guys are correct, once a button is stuffed its stuffed - nothing can be popped in.
cheers, Maka
Old 13-12-2014, 04:39 PM   #7
Uncle_Ken
Uncle_Ken's Avatar
Cool Re: Seek button missing on steering wheel audio controls
Yeap.. I took this pic at the wreakers you can see where the plastic has been broken.
UK
Old 13-12-2014, 05:56 PM   #8
Maka
Maka's Avatar
Thanks for that Uncle Ken much appreciated! When i had another look at the switch earlier today, i could see no where for the button to seat so i'll have to decide which way to go - splice into existing loom & replace the 3 buttons or just replace both sides. Its all good!
cheers, Maka
Old 13-12-2014, 05:59 PM   #9
Uncle_Ken
Uncle_Ken's Avatar
Well done! Have yesterday off
UK
