Old 15-11-2014, 07:45 PM   #1
icecold84
Default Replacing a radiator help
A mate of mine drives a vy s commodore and the radiator has **** itself, can anyone give advice into what kind of difficulty would it be changing it himself..??
BA II XR8 Full Difilippo Big boy exhaust, Bpr cai, Xcal 3 Custom tune, Mellings oil pump, Crow cams, Tuned By Bluepower Racing Developments 261rwkw
icecold84 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2014, 07:56 PM   #2
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
Default Re: Replacing a radiator help
Firstly source the parts. Sometimes it is hard to get a hold of parts. Buy all the parts required like top and bottom hoses, correct amount of coolant. Get the right radiator be it for manual or auto. Anybody with the right parts and tools and are mechanically minded can carry out the task. After instillation run the car up to temp, and so the thermostat opens and top up as required. Road test, look for leaks and keep an eye on it for a few weeks to make sure you have done the job properly. Make sure you clean the engine bay first, as if there is a leak you will be able to see white calcium deposits from leaking coolant.
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2014, 08:01 PM   #3
icecold84
Thanks, he will have a crack and doing should be ok with my supervision, I told him he should have bought a ford lol
Old 15-11-2014, 08:20 PM   #4
Davehoos
the radiator is fitted in assembly line as an assembly with air conditioner oil cooler-bottom of a/c- and oil cooler sometimes in both radiator tanks,, and fan.
Ive had to panel--reshape--beat the top mounts each side to allow the radiator to come out without the condenser attached. depends if its a daily driver or a show car.
also had oil leaks early in the models at the radiator as some use orings like the falcon power steer pump..
PS buy radiator hoses heater hoses heater tap cap and thermostat etc and flush then refill coolant with a 50/50 hlden compatible coolant. not as expencive as it sounds.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA-
Land Rover 88
.MIDCOAST NSW.
Davehoos is offline   Reply With Quote Multi-Quote with this Post
