Old 28-09-2014, 05:07 PM   #1
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Default auger size for retaining wall post
Hi guys,
Does anyone know the correct auger size to get for a post hole digger to use for putting in the Steel H sections for a sleeper retaining wall?
Is it 250mm?
Curent Rides:
-NC Fairlane Ghia 3.9L
-XC RallyPack Ute 5.8L
-AU Falcon Wagon 4.0L Still Stock
-80 Series LandCruiser 4.5 LPG
NC_Lane is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2014, 06:32 PM   #2
mechanic
Default Re: auger size for retaining wall post
In Qld. the council has to OK plans for retaining walls over certain height and I think the footing dimensions would be on the plans, don't know about Vic.
mechanic is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2014, 06:36 PM   #3
It also depends on the size of the post.
Old 29-09-2014, 01:25 PM   #4
ebxr8240
Performance moderator
ebxr8240's Avatar
300 mm or larger if it requires better footing .. Back filled with blue stone and concrete .. I would lean hole & pole 5*+ towards bank ..
Edit I would go 50mm above H section..
I thought it was a 250mm pipe ..
Daily driver GTE FG..
Old 30-09-2014, 07:49 PM   #5
Danny
GT4.
Danny's Avatar
450mm auger for a retaining wall is what to use mate. Order some concrete from your chosen concrete mob, or if you don't need that much, buy some readimix bags (NOT quickset - it's rubbish) which are structural rated, and enjoy mixing them yourself.
Old 30-09-2014, 09:33 PM   #6
Work Horse
Budget Racer
Work Horse's Avatar
Originally Posted by NC_Lane View Post
Hi guys,
Is it 250mm?
The size and depth of retaining wall footings vary depending on the height of the wall.
In Victoria anything over 600mm high requires an engineer, seriously.
12.1@112Mph 285rwkw on n2o Cleveland Power
Work Horse is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2014, 09:57 AM   #7
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Thanks Guys
Curent Rides:
Old 09-10-2014, 09:26 AM   #8
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Hi Guys,
How far do you think I can space the posts? i was told that i can use 1.8m 75mm sleepers with the H posts and it should be fine. Does this sound right?
Curent Rides:
Old 09-10-2014, 09:42 AM   #9
You need to give us some more information so we're not second guessing.
Height, length, H section, soil...
Old 09-10-2014, 09:50 AM   #10
Mont5.0
Mont5.0's Avatar
What sort of sleepers are you using? I assume timber. I used concrete sleepers with H beams to construct retaining walls at my new house, 1.8 was fine for them- but they have reinforced rods running through the sleepers. I think 1.8 spacing is to much for timber as they bow,
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is online now   Reply With Quote Multi-Quote with this Post
Old 09-10-2014, 11:21 AM   #11
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
height will be 1m length 15m, using H sections soil has a bit of clay on the bottom half
Curent Rides:
Old 09-10-2014, 11:32 AM   #12
Ross 1
Imo err on the side of caution. Put uprights at the halfway mark as well. Especially if the land behind slopes upwards and actually puts pressure on the sleepers. They will bow eventually, just through continual weather exposure, over engineer it for longevity
Ross 1 is online now   Reply With Quote Multi-Quote with this Post
Old 09-10-2014, 11:36 AM   #13
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Hi Mate,
I dont think I have the option of going uprights at the halfway mark as I am using H beams
Curent Rides:
Old 09-10-2014, 12:51 PM   #14
Ross 1
Will pm you my mobile number
