Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > New and Classic Ford Association of Australia Inc
New and Classic Ford Association of Australia Inc A Queensland based club for all Ford models of all ages of Show “n” Shine standard.
Old 09-09-2014, 05:36 PM   #1
wildfire
Default 3.3 to 4.0 litre project help
I have a 1983 ,,3.3 falcon in my Toyota coaster I would like help I want to change to a more power full engine keep it simple will a 4.0 litre bolt up to same adapter,,,is there a 4.0 litre that is still carbyed so I don't have to have computer modifications etc
wildfire is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2014, 06:55 PM   #2
Davehoos
Default Re: 3.3 to 4.0 litre project help
XD-XF 4.1 had a carby including post 1986 unleaded engines.
throttle body injection from 3.2, 3.9 EA , lot of AU taxi around converted to full gas with throttle body manifolds. even seen a turbo gas. wouldn't be too hard to get a carby manifold for a EA engine into a bus/camper.
have they used the 3.3 to make it easy for rego?
in the old days the regulation morrons came up with all sorts of silly ideas like only allowing a percentage increase of power or capacity. Im not up on QLD and a coaster was a commercial with a full chassis.. Ie 25% of 3 liter wont allow a 4 liter. but maybe a coaster might have had a big diesel option.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA-
Land Rover 88
.MIDCOAST NSW.
Davehoos is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2014, 05:52 PM   #3
wildfire
thanks great info is bolt pattern the same also engine mounts
Old 10-09-2014, 06:09 PM   #4
rag top
rag top's Avatar
from another thread:
1974 Ford XB Falcon runing a EB 4.0ltr OHC motor without EFI, Weber carby (XF), EA carby manifold with custom adaptor, EFI fuel pump, large extractors, 2.5" system with single Berkley muffler, T5 gearbox, standard XB/XC non-lsd diff, lovells front springs, extra leafs in the rear. Was a pretty simple conversion, although Im having a teething problem with the Weber. It is a bit hard to start sometimes like its flooding or something, also running the EFI pump without any regulator so it might be pumping too much fuel. Runs fine tho, big improvement over the old non-crossflow 250, and still a big improvement over the 250 cross-flow. The engine mounts look pretty standard, not sure, but looks like a straight forward swap.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
rag top is offline   Reply With Quote Multi-Quote with this Post
