Old 04-03-2014, 10:04 PM   #1
shyun
Default Accelerator pedal rubbing
Hi,
I just got an AU and one thing I noticed is the accelerator pedal hitting the carpet in the corner. The carpet doesn't go hard up against the body in the corner so it sticks out a bit below the pedal. If I push it to the floor it flexes the carpet and then pops out the plug (in the kick panel area where the looms are). Is this normal? The carpet seems aligned with everything else...Thanks
shyun is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2014, 01:08 PM   #2
BLU-220
FG XR50 TURBO
BLU-220's Avatar
Default Re: Accelerator pedal rubbing
Originally Posted by shyun View Post
Hi,
that's the first thing i notice when i first went for a drive in the ghia after i brought it, it was very annoying so i got a larger thick plug and put it a little bit higher up
cheers dean
BLU-220 is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2014, 01:21 PM   #3
Sox
RIP...
Sox's Avatar
I put a cut right in the corner to relax the carpet in all of my AU's.
Oval Everywhere...
Old 05-03-2014, 02:25 PM   #4
shyun
Cheers for the feedback, guess it isn't just mine then. You'd think Ford would have noticed at some point it doesn't fit properly, pretty silly. I'll probably just cut it in the corner as well
