24-02-2014, 12:29 PM | #1 | ||
Au Falcon = Mr Reliable
Hi guys, my antenna has just got stuck fully extended - i think that means the inside drive rope is snapped. Is a new full antenna needed or i can replace the old rope with new etc? Any info will be helpful thanks!
ps- just googled, not much info out there with this issue unfortunately. cheers, Maka
24-02-2014, 12:31 PM | #2 | ||
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! |
24-02-2014, 03:23 PM | #3 | ||
Thanks for link poppa, much appreciated!
Quick edit, just found this helpful info - http://www.fordmods.com/ford-audio-v...e-t108138.html cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) Last edited by Maka; 24-02-2014 at 03:30 PM. |
24-02-2014, 06:43 PM | #4 | ||
Pethy FG XR8 Ute
yep take old antenna mast out , just unscrews the nuts at the base of the mast from memory , turn on key and radio so the rope comes out pulling on the mast bit
once out feed new rope into antenna base then you turn off the radio and the motor should work in reverse grapping the rope and feeding it into the antenna base once the mast has gone all the way down put nut back on end. all good from memory as its been awhile since i did one
FG XR8 Ute 2010 Nitro, Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum Powerbond 25% under drives, Sports bar, now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset total of 285.5 rwkw and 642nm when Herrod cams in 290rwkw GSXR 750K7 with goodies, dyno'd 136rwhp, 10.567sec for the strip |
24-02-2014, 07:49 PM | #5 | ||
Hi. You may need to remove the drum cover at the bottom of the antenna and being careful of any washers remove the drum and take out any bits of broken cord from the old mast. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
25-02-2014, 08:54 AM | #6 | ||
Thanks for your great tips guys, it'll make the job way much easier!
cheers, Maka
02-04-2014, 04:14 PM | #7 | ||
Job done! Autobarn also had the replacement mast for $32, which i ended up getting. The hardest part of the job for me was removing the aerial grommet on top of the guard & coiling up the new mast cable to fit back into the spool casing, patience needed i tell ya!
http://fordforums.com.au/showthread.php?t=11371310 I also referenced The Interceptors excellent how to & that made the job a lot less daunting, anyone that needs to do this job should have look at this link above. Thanks to all who replied & helped out with advice - anyone that needs any help doing this job, pm me. cheers, Maka
2 users like this post: |
02-04-2014, 07:00 PM | #8 | ||
When in doubt, GAS IT!!
What is this coiling of the mast cable of which you speak?
Once the old toothed cable is gone, and with the ignition on, I have always just fed the end of the new cable into the aerial sleeve till it meets the drive cog then get someone to turn off the radio. The aerial motor just starts up and winds in the cable till the new mast is retracted and seated in the mast sleeve. job's right at that point and you just then have to refit the locking collar and put the whole thing back into position in the guard.
03-04-2014, 09:04 AM | #9 | ||
Hi Bushbasher, i opened the spool casing to remove the broken bit of chord & while the casing was open, i fed the chord into the antenna motor.
When the chord was fully retracted & the mast seated, i had to coil up the chord to fit it back into the clear spool casing (as per The Interceptors instructions) - it was a bit of a pita because i greased the chord up & it was a bit slippery trying to install it while the antenna unit was hanging down! Once you have a go at coiling up the chord a couple times, you soon work out the correct technique. All done & all good! cheers, Maka
