Old 14-02-2014, 12:42 AM   #1
rowan194
Default AU3 Fairmont: Hissing sound from climate control display
There is a vaccuum tube behind a small vent at the top left of the clock. Today it started audibly hissing, the level changing with engine load.
With the message display centre removed I can put my fingertip on the tube and it will stick within a couple of seconds so it has decent suction. Maybe TOO much suction, like there's a vac pipe blocked somewhere else?
Since the hissing started this has also happened:
- Twice the transmission held first longer than normal, and when it did change to second it was quite hard.
- Once the trans/diff did a 'clunk' when pulling up to a stop.
But apart from that:
- Engine is idling fine. No surging, no stalling, no RPM wandering aimlessly.
- Power and response seems to be normal.
- No obvious vac leaks within the engine bay.
- Transmission only played up the 3 times out of a couple of hundred gear changes. Could be coincidence.
Any ideas why this tube has suddenly started making some noise? (Note it is actually a tube inside the MDC, nothing to do with the climate control actuators further inside the dash)
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2014, 04:23 PM   #2
mif73
CNC fixer guy
mif73's Avatar
Default Re: AU3 Fairmont: Hissing sound from climate control display
I don't think I can recall any vacuum lines to the MDC /climate control unit, but I do know that a lot of temperature sensors in climate control units work by sampling the cabin air with a small fan or vacuum pump which draws air past a temp sensor.
Are you sure the noise isn't caused by a noisy suction fan/pump in the MDC?
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2014, 10:24 PM   #3
mif73
CNC fixer guy
mif73's Avatar
Well i just pulled out my mdc and guess what? There is a vac line plugged into it.
It looks like it is there to draw air over the cabin temp sensor thermistor.
I unplugged the fitting and there is a black filter type material on the end of the hose.
Old 15-02-2014, 01:04 AM   #4
rowan194
At which end? When I unplugged the hose (MDC end) the end of the connector was just open. Maybe the filter helps reduce the noise and it's slipped through?
Old 15-02-2014, 09:32 AM   #5
mif73
CNC fixer guy
mif73's Avatar
The filter was on the hose end, not on the mdc fitting itself.
Old 15-02-2014, 11:43 PM   #6
rowan194
Hmm... can you explain that a bit better? If you disconnect the hose from the MDC the filter is between the connector and the rubber hose? Still don't get it.
Old 16-02-2014, 12:33 AM   #7
mif73
CNC fixer guy
mif73's Avatar
The filter is actually stuffed inside the end of the hose about 10 to 20mm in (filter is not installed in the mdc itself).
I will see if i can take a pic tomorrow for you.
