I want to do the o2s, coils and leads on my AU V8.
What are the best items to fit? I see MSD make coils and they seem popular, are there problems with the MSD AU items? I know their E series coils are prone to fail. As for leads, I know top gun and eagle do them. I've been unhappy with the top gun ones in the past, I've had the fat Eagle ones and they seemed much nicer quality. Just a standard 175kw Ghia, I will be doing bolt ons though and I want quality stuff not rubbish that will fail in a few months. What are reccomended and what are the best sources? Thanks Windsor lovers. |
not here much anymore
Ive run MSD coils on 2 AU's and sold probably a dozen more sets with no issues. No hesitation in recommending them.
RAM 1500
Thats good enough for me.
What leads and O2 sensors have you used on your utes? |
#4 | |||
MSD are good but you can't get an 'off the shelf' set - they have to be made. If you want straight out buy and fit I would look at ICE or Eagle. As for 02's - Bosch ones via Ebay, direct fit 4 wire green connector. Expect to pay about $120 for a pair.
RAM 1500
Pro Street Au Ute
I did see o2 on ebay for 40 each. I've used msd coils and msd made up leads via a1 in wa. I just ordered a new set of msd coils from summit cause I sold my last set, no problem recommending them. But won't order leads from them again took 2 sets to get the colour I ordered. Tried summit for a kit to make my own with no luck so ill be going with ice.
Daily. AU XR8 s2 ute auto Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker. |
#6 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
MSD packs with Eagle leads on mine
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
How much Bottledup? I found a thread about the MSD leads you were making years ago, looks like you had some problems with them? I can't afford to muck around with sending them back etc if the boots are wrong or not crimped right, I need the car.
I've found VDO O2s on ebay, price seems good. Can't see Bosch there, VDO should be good too I'd think? Am I going to see a difference with the MSD coils for the extra money? Even a slight gain in response/torque/economy would be worth it. Whoosha I like the Eagle leads normally, looks like I would save about $50 going for NGK ones though. NGK does them with two different styles of boot to suit the Normal/XR8 exhaust manifolds. Tricky thing is I'm planning to fit XR8 manifolds or even aftermarket when I find some. Not sure where that leaves me. |
There was an issue with a group buy conducted through my old work (A1s), both with suppliers failing to provide and a colleague seriously dropping the ball while I was on annual leave.
I'm not doing these in bulk, I keep a box of wire and the required terminals at home and will build sets as required. Hence why I'm only offering black coloured lead, and after several different plug ends being tested I've settled on 115* extreme duty MSD boots on all 8 leads. I've found that these will clear pretty much every head/plug/header combination. ![]() Pricing is $200/set including an Express Post bag Australia wide. |
Lacking Imagination
Dave's leads dropped straight onto my motor, two needed redoing but that is becuase they foul on my AFR 185 Comp heads!
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
Sounds good to me, I'll get back to you asap.
#12 | |||
FG XR50 TURBO
![]() Join Date: Apr 2009
here are the ones on ebay genuine bosch http://www.ebay.com.au/itm/NEW-BOSCH...28cf28f&_uhb=1 genuine delphi http://www.ebay.com.au/itm/GENUINE-D...ba4a1ef&_uhb=1 genuine ntk http://www.ebay.com.au/itm/NGK-NTK-O...cf9e285&_uhb=1 cheers dean |
Whats wrong with them?
At that price I'll go the Bosch anyway, thats bloody cheap. I only searched under V8, thats where I went wrong! |
#14 | ||
Lacking Imagination
They are slow to Switch which will not give the EEC accurate Information.
#16 | ||
Lacking Imagination
Also PM BOTTLEDUP,
He is the best Parts Guy i know! he can also do some good pricing on parts and doesn't have an attitude like most
#18 | |||
CNC fixer guy
I just bought 2 bosch O2 sensors, off the ebay seller you linked as I was waiting for a good excuse ($40 each ![]()
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
#19 | ||
I've ordered a pair too, and the MSD Coilpacks.
#20 | ||
Q - CAR
Dropped in quick and i see your've got it covered.
MSD coil pacs - Tick Bottledup MSD leads - Tick Bosch 02 sensors - Tick
AU FORD STROKER 347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned. |
#21 | ||
Bottledups leads are great if you like leads that fall apart and are crimped together with a 10 dollar supercheap crimping tool, absolute junk
#22 | |||
Bahahaha, if I've inadvertently sold you some leads, I apologize and request you return them for a refund. |
#23 | ||
Cat be Still !!!
Dave, I don't think boi had an issue with your work or knew of anyone with alleged issue.........Just had to have one last stab on his way out from the haltech thread.
2002 AUIII XR8 n/a: 13.65@101.8mph. With Raptor Assist:..12.73@111.5mph. With ET Streets:......12.44@110.7mph, a one time fluke.........12.54@110mph back to back. With 3.9 Gears:.......12.40@112.5mph, still trying! Tune by XFT |
2 users like this post: |
#24 | ||
No worries Craig, hopefully he can cool off in the kindy sand pit playing Tonka trucks & building bridges.
#25 | ||
Q - CAR
I checked out his profile ... He had a history of creating trouble on the forums and had been warned numerous times!!
3 users like this post: |
#26 | ||
The leads fit nicely and feel great. Fast turnaround too. Big thanks to Bottledup.
All the parts are in along with the XR8 snorkel, new air filter and plugs. Also filled it with 98 to see if theres an economy difference. I drove it about 100kms today. Feels alot nicer. Very reponsive now and the economy was in the 11s after a short freeway run. It really runs out of puff above about 4K rpm, the next addition will be better headers and exhaust. Big thanks to all for the advice and help. |
#27 | |||
FG XR50 TURBO
ps. how did you SLO247 got them fitted yet ?? cheers dean |
#28 | |||
FG XR50 TURBO
#29 | ||
CNC fixer guy
Well i bought the bosch o2 sensors here http://www.ebay.com.au/itm/NEW-BOSCH...28cf28f&_uhb=1
And installed them and then did an ecu reset (disconnect batt for 30 mins while shorting power leads). When i started the car it ran rough and the auto held on to gears a bit long and i have noticed a rich smell even at idle with higher fuel consumption (i think). Engine and trans ran smooth after a bit of a drive. I checked with forscan and i am getting over 2 volt swings from my sensors at idle when at running temp. I thought they could only generate up to 1 volt? Wtf?
#30 | |||
FG XR50 TURBO
