Old 01-02-2014, 06:38 PM   #1
Clevor440
Default 440clevor build
Hi too you all this is my first post. I'm building a new engine for my falcon was just wondering what you guys thought 9.5 dart block, 4.125 bore 4.1 callies magnum crank, Oliver rods 6.2 kaase c400 heads, 13.5 comp 1100 pro systems dominator, comp cams solid roller 284 and 296 at 50, 860 in 800 ext with 1.75 t and d rockers. Have nitrous cp forged custom pistons going too run direct port fogger on it hope too run 9,s and hope too get 8 on the gas trans will be power glide once sorted in the xd I plan too put it in my capri when I've finished it thanks looking forward too yr input.
Clevor440 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2014, 08:12 PM   #2
u2canb12
u2canb12's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising cruises and keeping the events in the spirit of the forums
Default Re: 440clevor build
I have know technical knowledge but it sounds like its going to be a weapon.
Good choice of heads, Kaase C400 heads, got a set on my motor aswell
u2canb12 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2014, 01:10 AM   #3
Clevor440
I hope so lol, I'm looking too make 800 hp nat asp plus 200-250 gas,I just need a few more bits and pieces so I can start too put it together
Old 02-02-2014, 02:33 AM   #4
XW WA
XW WA's Avatar
welcome.to the forum.hell of a first post, do a build thread on your motor and get a photo bucket account and keep every one updated.sounds like an absolute missle you are building.what's it going in?
XW WA is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2014, 02:35 AM   #5
XW WA
XW WA's Avatar
Capri.got over excited reading the parts list and missed it
Old 02-02-2014, 12:41 PM   #6
Clevor440
Hi thanks for yr reply, I have an xd interceptor which I have been racing with a tongued 4v 351c, big cam ect, I always wanted a stroker so it's going in the falcon hoping to run nat asp 9,s and gasing it into the 8,s I have Caltracs adj shocks, 90/10,s hope too get mini tubs. Was going too run 275 x tires .
Old 03-03-2014, 11:03 PM   #7
JAYBA
Won't need mini tubs for those size tyres...
Keep us updated on your build in Cleveland section
434ci - XD
APR - 8V - S3
MKIII - RS
JAYBA is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2014, 08:47 PM   #8
Stefan
Stefan's Avatar
What's the go with new dart blocks and the like.
Do you now "legally" now need to comply with current emissions etc as this is essentially a 2013 / 2014 engine?
Do they have engine numbers or do you stamp them or what?
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2014, 10:58 AM   #9
XT302
They wouldn't have engine numbers, as for complying with 2014... Think about? It's just replacement parts only thing in the 70s in your car is the block and the head castings everything else is brand new ...
If it's a street car Stefan , his 13.5 comp and race fuel will be more of a legal issue
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2014, 11:16 AM   #10
XT302
Sounds like a nice car, what's the XD running as it sits?
Old 28-03-2014, 07:24 PM   #11
Stefan
Stefan's Avatar
Yeah i put legally in inverted commas.....so do I buy a new block then stamp my engine number on it? or just leave it and shrug my shoulders when the guy doing your rego check can't find the engine number?
Again rules are clear if the engine is of a newer model than the car you must comply with the emission rules of the engine year. I doubt anyone will look or care to be honest, but just curious, I think the engine number would be a bigger issue.
Old 28-03-2014, 08:46 PM   #12
jandj
Mate I think in regards to engine block , you go see cops for an engine number. And in regards to newer engines ( complete engines out of a newer vehicles with EFI) must have a mod plate and run factory ECU.
jandj is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2014, 02:31 PM   #13
XT302
In NSW police havnt issues engine numbers for about 10yrs, RTA/RMS and authorized agents can issue the numbers
Old 12-04-2014, 10:46 PM   #14
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
I looked into this for my Dart block.
Local engineer said you need 2 things....
Emissions test of the engine and a noise dB test.
If they come in under the allowable limits, then you will be able to obtain an engine number to have stamped on it.
Mines got 13.5. but I'll be running E85 which is quite clean on the emissions (bump it up to E90 for a test)......but it would be a laugh running a pig of an engine down low on their emissions dyno. They drive a specific profile of accelerating and cruising. You'd need 6 mufflers too and catalytic converters!! Not sure if the RTA dyno guy would like to see a few power runs whilst it's hooked up!!
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
