26-01-2014, 01:57 PM | #1 | ||
Hey guys so I have been through a few threads on brake upgrades.
From what I read ba calipers are different to au calipers and are slightly better. But are ba calipers different to like bf xr8/xr6t calipers or is it just the mounting bracket to suit 322mm rotors? Ive read the difference between stock au2/au3 and standard ba is not really worth it and for a bit of extra cash the 322mm upgrade would be much better. I found this little kit on ebay. http://www.ebay.com.au/itm/FORD-FALC...item417adee2c5 So would I just need to source standard ba calipers? and this kit would allow me to run the 322m discs? |
26-01-2014, 03:38 PM | #2 | ||
To use this kit on your AU s2-s3 you will also need a set of BA front callipers and a set of BF xr8/xr6t front brake lines.
The BF xr8/xr6t lines are longer. I have the BF xr8 front set up on both my AU3 xr8 and AU2 xr6 ute. Great upgrade. Cheers Dazza |
27-01-2014, 01:00 PM | #3 | ||
Alright thanks!
27-01-2014, 04:08 PM | #4 | ||
l have bf twin pot calipers and hoses if needed
gassa |
12-02-2014, 07:36 PM | #5 | ||
Anyone know whats needed to fit the bf premium brakes to the au, the 325mm disc?
12-02-2014, 11:24 PM | #6 | ||
[just bolt them on
gassa |
16-02-2014, 08:49 PM | #7 | |||
Q - CAR
Great brakes - same as PBR premium or Brembo 4 pot.
AU FORD STROKER 347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned. |
16-02-2014, 09:06 PM | #8 | ||
yeah I definitely don't want to remove any of the wheel weights
