Old 20-01-2014, 12:12 AM   #1
land2001
Default Ford Laser..KH what does the 'Hold' dash light mean?/
Hello Guys, the Daughters Ford Laser 1994 KH, auto. It's not engaging into the drives cleanly it seems to take a few seconds to engage.. A dash light 'hold' begins to flash, after reading manual it's saying that's it's electrical.. I think the auto and diffential have something to do with it..any ideas. please
land2001 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2014, 12:59 AM   #2
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Default Re: Ford Laser..KH what does the 'Hold' dash light mean?/
If I recall the 'hold' is a function of the shifter, maybe the switch in the shifter is dicky.
Well, actually a function of the transmission but controlled by that there shifter and 'hold' button next to it
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2014, 02:05 AM   #3
FGX-351
Supercharged Mang-mobile
FGX-351's Avatar
The car is simply placing you on hold while it receives a call on another line? lol
I'm temporarily driving a 91 laser atm, thankfully this is one of the few things it hasn't done to me yet.
09/00 VX HSV XU6 Build #0001 of 0171
http://fordforums.com.au/showthread....09#post5571209
-- Best E/T: |14.982 @92.12mph | R/T:0.013 | 60' 2.213| 330: 6.283 | 1/8: 9.624 @ 73.17mph | 1000: 12.529 | 25Deg, N/A Hum, 1010mb | Willowbank Raceway 7/12/16
Tickford EL Falcon XR6 RIP
-- Factory Manual
-- Best E/T: |14.991 @ 92.71mph | R/T: 0.607 | 60': 2.215 | 660': 9.665 |13Deg, 86%H, 1024mb, 184RA @ Willowbank Raceway
FGX-351 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2014, 06:16 AM   #4
Robdogg
FORDTORQUE
Robdogg's Avatar
The hold button is similar to sports mode etc but the light will only flash to indicate a fault. So it's off to your local transmission joint for some possible fault code reading and repairs.
Sent from my iPhone using Tapatalk
Robdogg is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2014, 11:04 AM   #5
kempy311
BEN
kempy311's Avatar
Sounds like it flashing a fault code it will need a scanner to pull the code so you know whats going on but most likely time for another box if it worth it.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2014, 01:31 PM   #6
land2001
Thanks guys for the tips.. after chugging the car to some mechanics, they all say it's the auto clutch that is on the blink. it means new auto clutch, quotes are $900 to $1200. because of the age of this laser being a 1994 model it's touch and go to fix.. But I think ill going ahead with it. thanks again guys
Old 20-01-2014, 03:53 PM   #7
kempy311
BEN
kempy311's Avatar
At that price its not worth it the car is only worth $1500 in good nick.
331rwkw.
Old 20-01-2014, 06:11 PM   #8
land2001
thanks Kempy311, it's probably not really worth it.. but I'll need to get the work done, then save up to buy something better..catch 22!!
Old 29-01-2014, 08:16 PM   #9
land2001
hello again guys.. finally got the 1994 Ford laser's auto transmission fixed, now the transaxle is making the dreaded grinding noise. it was the day after that my daughter tells me of the nosie. I take it back to the mechanice who says it was fine when he checked and set the throttle. How difficult is the job and, should I push it to say he's done a dodgy job? I think he has..by the way he was avoiding an answer
The car is a 1.8 engine front wheel drive.. what's the approx cost of the differential bearing repair.?? thanks for any info it would be appreciated.
