Old 24-12-2013, 08:45 PM   #1
mcfly94
mcfly94's Avatar
Default Best tyre for Tickford 17's (235/45)
Hey guys bought some 2nd hand tickford au2 wheels for my forte.
I think the tyres are compromising my ride comfort.
Run 34 PSI all round and the tyres are on the worn side.
Good year front and just some generics on the back.
Looking at replacing the tyres but don't know what would be best, Michelin, Continental, Pirelli, Bridgestone?
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2013, 08:48 PM   #2
rag top
rag top's Avatar
Default Re: Best tyre for Tickford 17's (235/45)
I'd get a wheel alignment first to try and work out why they are wearing on the side. otherwise, same will happen to your replacement tyres.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2013, 08:50 PM   #3
mcfly94
mcfly94's Avatar
Worn on the side when I bought the wheels.
Although I do need a wheel alignment but im changing all ball joints a week or so in the new year so no point to get one just yet.
Just want some recommendations on tyres and info on whats best for comfort/grip/no road noise
Old 24-12-2013, 08:55 PM   #4
sbutler
335 kw of goodness
sbutler's Avatar
If your looking for comfort & quietness there are no tyres better then the Yokohama 551 db
Believe me they are the best by a long way, BUT your gonna pay for the privilege. I have them on my XR6 turbo & they trans formed the car. But again they are not cheap. hope this helps..
http://www.yokohama.com.au/Tyres/ADVAN-dB.aspx
CAUTION!
STILL Contain's opinion's & fact's that may offend !!!
2012 GTP 213 black what was I thinking? NOW FOR SALE>>
http://www.fordforums.com.au/showthread.php?t=11439680
sbutler is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2013, 09:00 PM   #5
mcfly94
mcfly94's Avatar
Definitely does mate, don't understand how mates can drive on cheap crappy tyres that cost $100-150, I love a nice soft comfortable quiet ride!
Do you mind me asking how much you paid for your tyres? Just want an idea.
Old 24-12-2013, 09:31 PM   #6
sbutler
335 kw of goodness
sbutler's Avatar
I paied $265 a tyre, but mine are 245-35-19,
so a 235-45-17 would be much cheaper.
I'd guess under $200 a tyre, but you wont regret it..
CAUTION!
Old 25-12-2013, 09:29 AM   #7
FOCUSonTHIS
FOCUSonTHIS's Avatar
I am running Michelin Pilot Sport 3's on my XR. I got them for $216 a tyre. Also Bridgestone Adrenalin RE002 are good tyres also.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 25-12-2013, 01:31 PM   #8
graham_h
graham_h's Avatar
I'm a fan of the Michelin Pilot Sport 3's too.
Very grippy in wet and dry and very quiet.
That's why they are fitted to lots of Luxo Euro sedans
graham_h is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2013, 02:16 PM   #9
LPGUTE
LPGUTE's Avatar
Run 30PSI as the manufacturer recommendation more grip and comfort, i check it every week as i check the pressure when i fill up each week but i just live around the corner from the servo so the tyre temp is still cold.
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2013, 02:47 PM   #10
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
If theyre 8" wide rims you should be able to fit a 245/45/17 as well. Theyre a more common tyre size now as they fit them to the first FG XR6's, are both wider and taller than the 235's so will be both more comfortable and provide more grip.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2013, 04:18 PM   #11
mcfly94
mcfly94's Avatar
Alright so I have yokohama 551 db, Michelin pilot sport 3's and bridgestone re002's to consider
Anyone else confirm whats best for tyre pressures?
And would 245's clear, cars tickford/king low height now? Will never go lower though
Old 25-12-2013, 06:44 PM   #12
sbutler
335 kw of goodness
sbutler's Avatar
245s will be fine mate. As for pressure? you really need to work that out, your tyres will tell you if they are to hard or to soft by eneven ware. 34/36psi in the Yokohama's would be my starting point..
CAUTION!
Old 25-12-2013, 09:41 PM   #13
graham_h
graham_h's Avatar
38psi for my Michelins
Never had any issues with uneven tyre wear
Old 26-12-2013, 12:55 AM   #14
Vincenzo
Vincenzo's Avatar
As a big fan of Yokohama tyres since 1994 and running the V550Db on the XR6 I can honestly say that after three years of Topend monsoons and dry seasons you would be hard pressed to find anything better, wet or dry - YMMV
Cheers Vincenzo - personally I use 32psi - 34psi around town and 36psi on trips
$DO || ! $DO : try
try: command not found - (YODA the Geek)
"WRC is for boys, Group B was for men" - Juha Kankkunen 4 times World Rally Champion
Romanes Eunt Domus - 'people called Romanes they go the house' - You mean Romani Ite Domum
[SIGPIC][/SIGPIC]
Vincenzo is offline   Reply With Quote Multi-Quote with this Post
