Old 14-12-2013, 02:50 AM   #1
sic 40t
Angry car wont start
hi I have a 2000 model lazer injector. now I check for spark ok injector pulse ok no fuel coming but if I run power to the pump from the battery pump works but still wont start. so I changed the ecu ignition and barrel new key reader still wont start if I spary throttle body cleaner in it start for a second. also when I put the ignition on the pump does not prim up if in wind it over and let the key go the pump prims please help head ******
sic 40t is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2013, 05:11 PM   #2
Quinsta
Default Re: car wont start
fuel relay...! unsure of location, but if your pump runs straight from the battery but wont start off the key take a look at the relay, or the fuel pump fuse for start too..!!! HTH
Quinsta is offline   Reply With Quote Multi-Quote with this Post
