Old 28-08-2013, 09:01 AM   #1
mantaman1
mantaman1's Avatar
Default vacuum hoses
Is their a diagram of the vacuum hose layout for the 2.0ltr pinto, and what can safely be removed without compromising performance.
On our dizzy there appears two vacuum hoe inlets on the vacuum advance is this correct and wher do the hoses come from.
mantaman1 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2013, 09:55 PM   #2
Ramo
Default Re: vacuum hoses
Hey, mantaman. the other one goes to the termostat aluminium housing. Not sure why though, something to do with the emitions. Im thinking of doing the same to de-clutter the engine bay ( way too many pipes, and half of the system is blocked up anyway)
Ramo is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2013, 08:16 PM   #3
muzzy
muzzy's Avatar
The dizzy has a vacuum advance and vacuum retard, the valve on the thermostat housing was designed to provide timing advance when water temp is low, there should also be a tree on the intake manifold , all can be disconnected with out hurting economy, except vacuum advance, this is the one at the back of the dizzy
The vacuum advance should work from
about 1500 rpm up, can be checked, by disconnecting the hose to the dizzy over a few thousand rpm, the rpm should drop.
RS2000 5 speed
Twin 44idf webers + other goodies
muzzy is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2013, 08:38 PM   #4
mantaman1
mantaman1's Avatar
Okay so I guess just check and block up vacuum points on the carby.
Old 02-09-2013, 09:03 PM   #5
muzzy
muzzy's Avatar
You need only 1 vacuum port on the Carby, it will have no vacuum at idle and full vacuum at about 1500rpm
RS2000 5 speed
Old 03-09-2013, 06:04 PM   #6
mantaman1
mantaman1's Avatar
Okay vacuum line to keep: vacuum advance and brake booster?
Old 03-09-2013, 07:05 PM   #7
muzzy
muzzy's Avatar
Yes that is correct vac booster will come direct from intake manifold
Vac advance come from Carby, above base idle, if its a std 32/36 dgv weber it will come from a vac port on the barrel / butterfly that opens first. If its the 38dgms it doesn't matter as they both together
RS2000 5 speed
Old 03-09-2013, 10:19 PM   #8
mantaman1
mantaman1's Avatar
Thanks Muzzy
Old 04-09-2013, 10:13 AM   #9
mantaman1
mantaman1's Avatar
Okay removed hoses today and fitted KN SPORTS FILTER.
Hoses remaining are vacuum advance from carby barrel through some kind of check valve (black and white plastic)?
Hose from thermostat the vacuum retard
Hose from inlet manifold to something attached to the side of the right side of the carby that heater hose runs up to?
hose to charcoal canister from hose with tee at rear of carby attached to inlet manifold.
Old 04-09-2013, 07:25 PM   #10
muzzy
muzzy's Avatar
[QUOTE=mantaman1;4870784]Okay removed hoses today and fitted KN SPORTS FILTER.
Hoses remaining are vacuum advance from carby barrel through some kind of check valve (black and white plastic)? Filter to prevent petrol vapour damaging the vac diaphragm
Hose from thermostat the vacuum retard not needed
Hose from inlet manifold to something attached to the side of the right side of the carby that heater hose runs up to? Manual cars have deacceleartion valve on side of intake manifold, all vehicles have heated intake
hose to charcoal canister from hose with tee at rear of carby attached to inlet manifold.[/QUOTE, answers above
RS2000 5 speed
Old 04-09-2013, 09:49 PM   #11
mantaman1
mantaman1's Avatar
Cheers.
