Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 06-08-2013, 10:56 PM   #1
dl86
dl86's Avatar
Default FPV GT Shockworks Coilovers
Thought I'd kick off this thread with some product pictures of the coil overs I recently received from Brett at Shockworks for my 2012 FPV GT MK II.
dl86 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2013, 02:16 AM   #2
dragons90
Default Re: FPV GT Shockworks Coilovers
Do you have any pic of them installed.
Thanks Gerard
dragons90 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2013, 03:11 PM   #3
dl86
dl86's Avatar
Here are some more pictures. Hoping it would help dummies like me who never installed suspension before. Still evaluating the overall handling of the car, but from what I have experienced so far the car handles like night and day compared to the factory set up at 2 clicks above from soft which has a maximum of 10 clicks.
Old shock and new shock
6 users like this post:
Old 11-08-2013, 05:06 PM   #4
dragons90
Cool thanks for them, is that the adjuster on the bottom of the rear shock.
Gerard
Old 11-08-2013, 05:54 PM   #5
dl86
dl86's Avatar
Yep, its covered a bit by the rubber sleeve. You can't really see it underneath the car, its just a matter of feeling it when adjusting it. Going harder makes it harder to turn and going softer is easier, so I just dial it all the way back down to soft then go up from there.
Old 11-08-2013, 08:11 PM   #6
nelsonian101
nelsonian101's Avatar
Good to see some $ on handling!
Have you tested them out on the circuit yet?
http://www.fordforums.com.au/showthread.php?t=11396563
FG XR6T ZF
350,000kms+
Road registered Lap record holder at Wakefield for any Ford or 2wd 4 door, of any make.....ever!!
Wakefield 1.07.4 SMP GP 1.48.1 Marulan 43.4 Winton 1.35.4
nelsonian101 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2013, 09:37 PM   #7
dl86
dl86's Avatar
Nah mate. Just got the heights dialed in today.
This was the first upgrade I felt absolutely necessary on this car when I bought it. Just felt too disconnected from the road.
Still haven't taken it to the track since I bought it, but plan to as I now have the tires (Bridgestone RE11) and suspension in check for some proper track work.
Old 21-08-2013, 12:11 PM   #8
nelsonian101
What is the spring rate on the rears?
FG XR6T ZF
350,000kms+
Old 22-08-2013, 04:40 PM   #9
dl86
dl86's Avatar
Spring rates are 9kg front and 7kg rear. Could probably go higher for a more track orientated set up. Brett can do custom spring rates.
FG MKII GT ZF, 444.8rwkw, 61mm YT snout, 1000cc injectors, 460lph fuel pump, big kpm intercooler, shockworks w/12kg front springs, SSR GTX01 18X9.5" +22 F/R, nizpro input shaft, 1pce 4" AL tailshaft, poly bushings all round, trutrac, headerback exhaust 3", whiteline sway bars, IMS diff hat, herrod spark booster, Alpine R type speakers/Alpine R type 2x12" ported subs/Pioneer GM-D9601/8604 amps and other bits
Old 05-09-2013, 06:22 PM   #10
Shockworks
Hey dl86,
I think you will be surprised with the performance at the track with the current rates. The overall balance we found to be great for a combination of high speed corners, but also very good for the slower parts of the track like Winton or Sandown. I hope you having fun mate!!
Brett
Shockworks is offline   Reply With Quote Multi-Quote with this Post
