Old 30-07-2013, 06:58 PM   #1
OzJavelin
OzJavelin's Avatar
Default What corrodes aluminum?
I just noticed my wife's horse float had what looked like corrosiön on the aluminum "guard" over the front of it. On closer inspection I noticed the guard has been corroded right through, including the body?
I don't really care about the trailer, but I'm concerned the FG ute she tows it with, as I'd suspect whatever is over the float probably came from the road while she was towing it with the ute. Had a quick look under the ute and can't see any marks like the ones on the float?
I'm assuming it's probably not something like salt because aluminum doesn't corrode from salt does it? Any chemists out there?
(BTW don't live near the sea .. Havent driven thru water, etc)
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2013, 07:03 PM   #2
Nikked
Oo\===/oO
Nikked's Avatar
Default Re: What corrodes aluminum?
Is the corrosion in a specific spot, like around a inner frame etc?
Aluminium will corrode if it is in contact with other ferrous metals...
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2013, 07:05 PM   #3
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
Yep dissimilar metals always a huge problem for alloys. As in where one type of metal is in contact with another type of metal, and then to make things worse the washer is then made out of yet another material again to make things even worse again.
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2013, 07:43 PM   #4
babyf6
Young Ford Enthusiast
babyf6's Avatar
http://www.clihouston.com/knowledge-...corrosion.html
hope this helps
Ol Reliable: 2004 Ba Sr MkI
The Fun Machine: 2007 Bf XR6 Ute MkII
babyf6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2013, 07:50 PM   #5
Thornie
Off smelting
Thornie's Avatar
I feel bad, I make the **** and I cannot answer your question lol.
2008 FG falcon xr8 in nitro, 6 speed manual, Djr bobtail, 20's, growler intake and manta twin 2.5 inch exhaust.
Thornie is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2013, 07:59 PM   #6
burnz
VFII SS UTE
burnz's Avatar
check the earth wire in the harness, its possible the earth was supplied by the tow ball itself.
bad earth kills alloy.
GO SOUTHS
Old 30-07-2013, 08:41 PM   #7
b0son
caustic soda
b0son is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2013, 09:15 PM   #8
ebxr8240
Performance moderator
ebxr8240's Avatar
Galvanized steel and alloy is bad news..
Sounds like metal corrosion ??
Can also be electronisis..
Esp if there's white powder like substance ...
Daily driver GTE FG..
Old 31-07-2013, 03:04 AM   #9
XP6
Formerly ST170ish
XP6's Avatar
Yep caustic soda and heat
My bad attitude escalates in direct proportion to the amount of stupidity I am presented with!!!
XP6 is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2013, 03:48 AM   #10
Pedro
Pedro's Avatar
Yep, aluminium guard connected to steel frame = electrolysis
Pedro is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2013, 08:00 AM   #11
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Hey Thornie, I am with you, same problem. And am just over the fence at QAL! lol
That said, Caustic Soda corodes aluminium.
Old 31-07-2013, 08:38 AM   #12
Shambles
Knucklehead
Shambles's Avatar
Anything you can do to stop dissimilar metals from touching directly will help. When you put steel bolts through aluminium use a little light grease. What is occurring is galvanic corrosion, the process where dissimilar metals act like a battery with the presence of a liquid. The aluminium being lower on the galvanic scale will corrode. Ensuring that the panels are electrically bonded to the rest of the structure will help as well. Any corrosion can be removed and neutralised with dilute phosphoric acid. Just be sure to reprotect the metal again with paint.
Shambles is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2013, 08:55 AM   #13
ebv8
ebv8's Avatar
can you use a sacrificial anode like what they run on outboard motor legs? you can buy them from any boating store and bolt it through the alloy. these are supposed to corrode first and be replaced when needed
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2013, 09:23 AM   #14
FGII-XR6
FGII-XR6's Avatar
an easier question would be what doesn't corrode aluminium, aluminium is fairly reactive and corrodes quite easily, just because some aluminium on a trailer has corroded I wouldn't automatically assume the worst for your car as it is steel. This is one reason I have never been able to understand the move to alloy body panels on cars
[SIGPIC][/SIGPIC]
Rides:
Old 31-07-2013, 09:26 AM   #15
big_landau
salt air! i have seen places on the coast where the salt air has totally corroded the aluminium windows from houses/units etc.
big_landau is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2013, 09:35 AM   #16
FGII-XR6
FGII-XR6's Avatar
instead of regular grease silicon grease provides better protection due to it's high dielectric properties
[SIGPIC][/SIGPIC]
Rides:
Old 31-07-2013, 10:21 AM   #17
Take a look at a Galvanic Chart.
You'll see Al is right up there
Here's a PDF I just found
http://npfasteners.com/pdfs/galvanic...sion-chart.pdf
Old 31-07-2013, 10:28 AM   #18
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
I'm no metallurgist and I agree with the above possible causes. You mentioned that this has occurred on a horse float - without me seeing where the corrosion is, could it be urine from the horses coming in contact with the aluminium? Just a thought.
Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2013, 10:58 AM   #19
Silver Ghia
Silver Ghia's Avatar
Originally Posted by supershifty View Post
I'm no metallurgist and I agree with the above possible causes. You mentioned that this has occurred on a horse float - without me seeing where the corrosion is, could it be urine from the horses coming in contact with the aluminium? Just a thought.!
Good thought. Horse urine residue definitely promotes corrosion in aluminium. Maybe the float has been hosed out on occasions with the water contacting the frame, this would certainly accelerate the corrosion process.
Years ago I was with an airline that carried horses in horse box pallets in freighter aircraft, the boxes were lined to prevent any spillage onto the aircraft structure, but the aircraft floor structure and bellies were always badly affected by corrosion and having to do extensive repairs at each overhaul.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2013, 03:19 PM   #20
mik
mik's Avatar
even water can corrode aluminum(usually when wet for extended periods), , the floor on my truck was like swiss cheese,
also electrolysis as already mentioned, i seem to remember water running off rubber onto aluminum can also cause corrosion, i remember that from 30 plus years ago(not bad for an old codger ).
Old 01-08-2013, 03:27 PM   #21
Addz08
"FEED IT"
Addz08's Avatar
Lime... From road base at roadworks..
BA XR8 UTE ,PACEMAKER 4/1'S,MAGNAFLOW METALCORE CATS,TOYS CUSTOM TWIN 2 1/2 SYSTEM, CAPA TUNE, K&N FILTER, LIGHTENED BILLET STEEL FLYWHEEL, DCS CLUTCH, SS INDUCTIONS BIGMOUTH CAI, 20" FR20 SIMMONS....
Addz08 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2013, 06:51 PM   #22
BOOSTEDGAZ
When in doubt-MORE BOOST!
BOOSTEDGAZ's Avatar
I used to build Aluminium superyachts and even with marine grade alloy, sacrificial panels etc the alloy had a limited life expectancy of aprox 7 - 10 years off memory so normal alloy will easily corrode over time due to acids, alkili's and electrolysis etc.
BOOSTEDGAZ is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2013, 08:21 PM   #23
ebxr8240
ebxr8240's Avatar
Plenty of GOOD etching / priming paint, rubber, sikaflex between joins to steel..
Keep in mind the top half of Queen Mary [one of them ships?] is alloy and it needed attention big time..
Some graphite grease or electrical jointing compound to keep water out..
At the same time have all panels electrically bonded to prevent electrolysis.
Sacrificial alloy mainly works in water..
Wash area with kero once or twice a year to wash out water..
