Old 23-07-2013, 08:48 AM   #1
Insidious
Insidious's Avatar
Default Tyre size calculator
Found this site that might be of interest to someone looking to up grade their rim size..http://www.inawise.com/tyre-calculat...alculator.html
Wish list....Pacemaker headers,hi flow cat done, 2 1/2 sports system done, flash tune and dyno..DONE
07 TX RWD Territory
Insidious is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2013, 09:06 AM   #2
Sox
RIP...
Sox's Avatar
Default Re: Tyre size calculator
Similar to this one -
http://www.miata.net/garage/tirecalc.html
Which has been around forever.
Oval Everywhere...
Old 23-07-2013, 09:21 AM   #3
2011G6E
2011G6E's Avatar
I used that "inawise" one when trying to track down an available tyres size that wasn't too far out of the original size of the ones on the Supra wheels on my old Celica.
That was because the only available tyres in original, slightly oddball size meant I had to bend over without lube and get a bank loan to pay for them, instead of paying a reasonably normal price for them.
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2013, 09:31 AM   #4
Silver Ghia
Silver Ghia's Avatar
Bearing in mind that tyre rolling radii do vary slightly with different tyres of the same size, also when they wear and with different tyre pressures.
So with the speed cameras prevalent, its best to check your speedo against a good GPS every now and then, and after fitting new tyres. Also with the tyres at the pressures you use, at running temperatures.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2013, 09:42 AM   #5
Mr Brooksy
Youth worker
Mr Brooksy's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Numerous helpful how-to's and sound advice!
I have an app on my phone which means I have it on me all the time.
Free Tire Calculator. Well worth it as its free and if you use a smartphone you have it on you all the time.
2007 FPV F6 Typhoon BFII, Neo. Build Number 325
2011 SZ Territory
Old Futura thread:
Brooksy's Ex Build
Mr Brooksy is offline   Reply With Quote Multi-Quote with this Post
