Old 25-06-2013, 01:06 PM   #1
Bosco26
Default Replacing Exhaust manifold gasket - V8 AU Ute
Hi all,
I need to replace the exhaust manifold gaskets on my 2002 V8 AU Ford as they're leaking..
I've had a look at the tech resources but there isnt any info there, that I could see...
Can someone give me a basic rundown on how to do this, what to look out for, tips etc??
The ute has pacemaker headers/extractors.. Also what gaskets should I use and is there any additional sealant I should buy to use along with the new gasket?
I have access to a hoist, not sure if this job is all done from the top or if it can be done from the bottom?
Cheers,
B
Bosco26 is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2013, 07:50 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: Replacing Exhaust manifold gasket - V8 AU Ute
Best to do from above - no need for hoist. You will need an allen key the right size to fit the factory bolts assuming whoever fitted your headers re-used the factory bolts, which a lot seem to do. Personally I would replace them with ARP's while you have it apart as the ARP ones only need a quick nip up with a 3/8" ring spanner - a lot easier.
Other than that it's just like replacing any other gasket - clean the surface of any residue from old gasket, seat the new one and bolt 'er up. All the AU 8's I've owned have always had the bolts come loose over time too, I made it a routine maintenance thing to check them.
RAM 1500
Old 26-06-2013, 10:41 AM   #3
Bosco26
What exhaust manifold gaskets should I get? I had a quick look online and they talk about "small port" versions etc??? My ute is a 2002 AU XL V8...
Old 26-06-2013, 01:51 PM   #4
BOTTLEDUP
Felpro 1415 is my pick of the gaskets.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2013, 02:52 PM   #5
FAT245
Lacking Imagination
FAT245's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Nath deserve's a Technical Contributor award for his willingness to share everything in his vast knowledge of tuning EEC-IV and -V Falcons, not to mention engines!
The Felpro's work well, Just replaced mine with them.
Also the passenger side extractor can be a pain, i suggest you unbolt the ancillaries bracket from that side of the engine and move it forward to proivde you with enough room.
My 11 Second AU Fairlane
364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W
FAT245 is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2013, 03:53 PM   #6
Bosco26
Okay i've had a look, the bolts are all tight, albeit rusted too... whoever fitted the pacemaker headers, changed the bolts too, so they're now hex head bolt...
I'd like to replace them as well while i can, what size bolts are used to secure the exhaust manifold to the heads?
Cheers!!
Old 02-07-2013, 04:39 PM   #7
FAT245
Lacking Imagination
FAT245's Avatar
They are 3/8 UNC Thread, The ones i used on my motor were roughly 1" - 1-1/4" in length.
You can get the ARP 12 Point headed ones from ebay but they are too short and will come loose.
Old 03-07-2013, 08:58 PM   #8
b2tf
b2tf's Avatar
Use the ones to suit small block chev and you won't have a problem.
RAM 1500
Old 03-07-2013, 09:00 PM   #9
FAT245
Lacking Imagination
FAT245's Avatar
I've ordered a set for my di filippo, cheers Austin.
Old 03-07-2013, 10:05 PM   #10
b2tf
b2tf's Avatar
For anybody interested this is the header bolts I got. PN is ARP-100-1202 and they come in a pack of 16. You can also get them in a stainless finish too.
RAM 1500
Old 03-07-2013, 10:10 PM   #11
FAT245
Lacking Imagination
FAT245's Avatar
They are the ones which i had Austin ...
The ones Fabre sold me are the 100-1211's (I had to buy 4 extra bolts)
The 100-1202's are .750" Long
The 100-1211's are 1" Long
Old 03-07-2013, 11:27 PM   #12
b2tf
b2tf's Avatar
Dunno what to tell you. I put those ones on the last AU and they were fine. Never came loose either.
RAM 1500
Old 03-07-2013, 11:29 PM   #13
FAT245
Lacking Imagination
FAT245's Avatar
who knows. lol
Old 05-07-2013, 03:55 PM   #14
Bosco26
Hi guys, got some new bolts and a set of Fel-pro 1415 gaskets.
regarding the gaskets, do I put it on as is, or do I need to use it with some other sealant as well?
thanks in advance for all the help you guys have given so far
B
