Q - CAR
Hi - recently installed new engine after a 7 month wait and i can not remember where this sensor goes.
In the image the sensor is draped over the radiator hose and has green tape to highlight. It comes off the injector harness at the same place where the cam positioning sensor, Timing sensor and started motor sensor are located. ... meaning there is 4 wires branching off at the same place. Can someone tell what the 4th is ??? 1 -Cam positioning 2- Timing 3- Starter motor 4 - ![]()
AU FORD STROKER 347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned. Last edited by bluestripes; 28-06-2013 at 07:03 PM. |
Lacking Imagination
if it is coming off the front and has two plastic holders coming off it, it would be for the oil sender?
If it is a spade connector, there is a oil sender on the side of the block next tot he water pump. It sits under the ancillaries bracket for the PS and A/C Pumps.
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
