Old 19-03-2013, 10:14 PM   #1
aranciaman
Default Carb Tuning
Hi guys, new to this so here goes. I have just purchased a 76 escort van with a 2.0 fitted to it to do up as a project. I have been trying to work out the carb but can't find any information on it. It has a tag that is stamped as this... Weber 76HF ABA A9A19. I am trying to find the air fuel mixture adjustment if it has it. I have found two screws, one either side of the float bowl that appear similar to those I have seen on the four barrels fitted to v8 engines that allow you to adjust float level... That's what they look like anyway. Adjustment in or out does not seem to make a noticeable difference so I am wondering, what do they do, what is the carb type and where do I find info on it?
Any info is appreciated
Thanks
aranciaman is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2013, 11:30 PM   #2
JimStone
Default Re: Carb Tuning
Weber 32/36 DGV
Two 'screws' you have been playing with are the idle jet holders
Pic below for main adjustments
HUGE amount of info out there for these carbs - search internet for 'Weber 32/36 DGV'
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2013, 07:36 AM   #3
aranciaman
Love your work. Thank you. They were very loose though for holders. Neither of them were tight and at various stages of coming out. I will re investigate them tonight. Thanks.. That is the main thing I wanted as well 32/36 DGV
THANKS AGAIN.
