Old 08-02-2013, 07:13 PM   #1
ben131185
Default front strut replacement
just about to replace the front struts on my au1.
picked up some new lowered ultima's off ebay and spring compressors.
is it as simple as jacking up, unbolt top and bottom of strut, remove, then put springs etc on the new strut and refit?
is a wheel alignment necessary afterwards?
ben131185 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2013, 07:36 PM   #2
BHDOGS
Default Re: front strut replacement
yup unbolt big nut from bottom of strut and 3 nuts from top of strut in engine bay, leaver lower control arm out of the way with a breaker bar or jack handle or remove swaybar links only 2 bolts and take it out and replace shocks. refit.
Old 09-02-2013, 04:07 AM   #3
peterljohnson55
peterljohnson55's Avatar
I heard this week that it is necessary, for rego/road worthy to have boots fitted to the struts. Is this true?
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2013, 04:15 PM   #4
BHDOGS
ive never heard of that but i live in s.a we dont have roadworthys
Old 09-02-2013, 05:21 PM   #5
Papa Smurf
Papa Smurf's Avatar
New one on me? never heard of this before, what sort of boot? I just had my Silver AUIII passed in December and my AUI in October, no one mentioned that.
I think someone is pulling your leg.
As to changing, I just changed the Struts and control arms on the AUIII and I found it is MUCH easier to remove the upper control arm as well, makes the removal of the struts easier.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 12:25 AM   #6
peterljohnson55
I have emailed the question about the strut boots to NSW's Roads and Maratime Services and should get a reply early next week.
Ben131185, I am not intending to hijack your thread here, but thought the side topic important given your proposed work.
Old 10-02-2013, 03:13 PM   #7
rmack
rmack's Avatar
I don't think you would need them. The OEM don't have boots on them and they passed ADR at the time.
Edit:
Just looked at the FG no boots there either.
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 03:32 PM   #8
FGII-XR6
FGII-XR6's Avatar
alignment not essential but it's always a good idea when you change front end components
[SIGPIC][/SIGPIC]
Rides:
Old 10-02-2013, 06:09 PM   #9
EBW-302
EBW-302's Avatar
Yep, Id take upper control arm off too, much easier!!
2009 BF MK3 XT EGAS WAGON
PREVIOUS RIDES: 2002 AU3 FORTE EGAS WAGON - 1995 EF GLi WAGON - 1991 EB GL WAGON V8 - 1998 EL FAIRMONT TURBO
phat GUARD ROLLING | 0429 093 302 | facebook
"CHEAPEST GUARD ROLLING IN MELBOURNE"
EBW-302 is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 09:04 PM   #10
ben131185
ok i got it all done. was pretty easy once i worked it out.
unbolt bottom, unbolt top, unbolt swaybar link, disconnect the upper ball joint from steering knuckle, pull it all out. change over spring and upper mounts and refit.
2nd side probably too about half an hour or just over all up with removing and refitting wheel and torquing nuts up to spec.
only thing i was a bit unsure about was the new struts have a hook on them, the old ones don't. i refitted with the hook facing the centre of the car. i would have thought facing outwards would have been more likely, but i fitted them back in so both top and bottom spring mounts were facing the same way as before which left them on the inside.
they don't look like they'll foul on anything but i can't see what the idea of them is.
Old 10-02-2013, 09:10 PM   #11
rmack
rmack's Avatar
I think Hook is for the brake line. I think it faces the wheels.
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
Old 10-02-2013, 09:17 PM   #12
BHDOGS
yeh hook is for the brake lines and faces the wheel
Old 11-02-2013, 02:36 AM   #13
peterljohnson55
Pic shows relationship of bracket to other stuff - no interference.
Old 11-02-2013, 09:29 PM   #14
ben131185
oh well mine are facing the wrong way then.
